Harmonics in output waveform of oscillator?
kriskris003
Newbie level 2
how to measure the harmonics in output voltage waveform of a voltage contolled oscillator using pspice simulator?
It´s relatively simple:
1.) Perform a TRAN-Analysis and measure exactly the period resp. frequnecy.
(Hint: Don´t use the PSPICE macro for this - it is not exact enough)
2.) Perform another TRAN-Analysis with FOURIER enabled (specify the fundamental carrier)
3.) Check the output file *.out. At the end of the file you will find the level of all harmonics and the calculated THD.
HINT: Don´t use the FOURIER option in PROBE (it is a FFT and very roughly)
