hard disk not detected while booting??
ambi
hi genius ..
i am trying to install the OS in my PC but hard disk not detected..:bang:
MacBootCamp.jpgScreenshot #1.jpgis there any solution for this?? pl check the attachment
did u change in the bootmenu ??when u start the pc first u should change bootdevice to DVDROM
Reactions: ambi
    ambi
Yes fahim1
Yes fahim1
try to install windows with another dvd.or try this dvd on another windows to find out it works.
Reactions: ambi
    ambi
but the problem is with the hard disk itseems??
yes but it is possible that you dvd dont work properly
No @srizbf
one hard disk and one dvd drive @srizbf
just see whether hdd and dvd drive are connected in the same sata cable.
if so, connect them each separately to separate sat port in the motherboard
Reactions: ambi
    ambi
Hi srizbf its been connected separately then too hdd not detected? :-|
In the harddisk , there will be a jumper configurable option.( near the connector end)
one , 'MS' and other 'SL'.
check the position of the jumper.
Reactions: ambi
    ambi
hi srizbf
i am using only one hard disk and there no other slave so there is no jumper in my hard disk
hi sunnyskyguy
its an seagate and sata hard disk
what is power check?
hi srizbf
whether one or more HDD , there will be a jumpe in proper position.
As suggested by sunnysky , make sure that hard disk is spinning.r
There's no master/slave and usually no jumper with SATA HDDs. And of course one SATA cable per drive.
If there's any problem with disk or CD/DVD drives, I would primarly look at the HDD information given in the BIOS menu. How about the DVD drive, is it recognized? If so, did you try to connect the HDD in place of the DVD?
Some old BIOS versions may have problems with some drives. E.g. incompatibility issues with SATA 2.0 or 3.0. If it's an old motherboard, I would try with a first generation SATA 1.0 drive. And generally try a different drive to sort out HDD defects.
Reactions: ambi
    ambi
Do you still need help? Looking at your screenshot #2 asking "where do you want to install windows?"
Click on Drive options (advanced). Does a hard drive choice show there?
Sometimes you need a correct partition to show in the list unless you choose advanced options.
Use advanced options to delete any previous partition record shown there.
WARNING - ALL DATA ON DRIVE WILL BE ERASED IMMEDIATELY
Then format the drive in that menu will create a partition.
Larry G
first of all check hard drive status in BIOS if available there then you have to need to change your HDD. you have no option every thing will make you headeche :)
