handling ISR in ATMEGA32
Jayk
Junior Member level 1
Rajkot,India
I want help in writing ISR in atmega32 programming.In my program i have two interrupt one for ADC and another for timer0 overflow flag.I want to call the ISR on timer0 overflow.how can i write the code ?
If someone translates that strictly then you cannot call an ISR, it comes when you don't expect it (that's why it is called "interrupt").
If you mean that the ADC interrupt must run in any case, then all you have to do inside timer's interrupt and in the first line of this function, is to enable interrupts globally:
void TimerIsr (void)  //random ISR name
  asm("sei");
Don't expect something more fancy like interrupt priorities etc, AVR interrupt system is not that advanced.
Hope this helps.
