T
treez
Hello,
We are using ACS770LCB-050U-PFF-T hall sensor.
On page 5 of its datasheet it says the min load resistance from VIOUT to ground is 4700R. It also says the maximum load capacitance is 10nF.
Does this mean we have to connect at least 4700 (or lower value) from VIOUT to ground?
Also, does it mean that we may not connect more than 10nF from VIOUT to GND?
Why does the diagram on page 1 show no resistance from VIOUT to ground?
ACS770LCB-050U-PFF-T Datasheet:
https://www.google.co.uk/url?sa=t&r...et.pdf&usg=AFQjCNEj1QgkSJu44S5o_0ArNz8Zi1ZXTw
Also, why does the 'VIOUT' output need an RC filter as in the diagram on page one?...is it due to the high ripple output caused by the chopper stabilization technique?
