Salvador12
Full Member level 4
Hi folks , i'm having a weird problem , now my smps worked and all was ok until i needed a small repair and accidentally by mistake blew my switching IGBT'S , now I replaced them with new ones of a different kind but before turning them on I checked whether all is ok with my gate drive IC's , I replaced the IC (IR2110) and checked the supply voltage which is 18 volts and is stabilized with the help of 7818 voltage regulator transistor.
Now as soon as I added the gates to the IGBT's I switch on the smps and it doesn't work , I measure the gate voltage supply and it has fallen as low as 5 volts which is below threshold so the IC doesn't drive the IGBT gate in order to save it from half open failure.
I can't understand wha has gone wrong , my gate drive is very simple two IC's a small traffo and a diode bridge and voltage regulator, I checked the gate drive supply with a resistor load and I calculated the voltage drops under different resistances and my gate power supply is capable of about 180-200 mA of current , but that was with a 39 ohm resistor and the voltage dropped to some 8 volts , so I assume at steady 18 vols the amperage would be lower something like 100mA no more , is that enough for gate drive ?
But my previous IGBTS worked just fine , so I can't understand.
the IGBT's seem also similar ,
my previous IGBT was STGW80V60DF and they worked fine until I accidentally short circuited them.
the current IGBT's are FGH60N60SFTU.
Could it be that the IGBT'S are faulty and leak gate current or what else ? or could they be different as they need more gate current?
hard to understand , so yeah my question is basically how much of a current at what voltage is needed for a safe and good half bridge gate drive ?
