hai problem with desktop
subbu39
Newbie level 1
hai i am subbu
recently i had a problem with my desktop. i don't know what happened to it
it suddenly gets turn off while i am working.
first i thought that the problem is in front pannel of cabinet.
but later i tried to format my desktop
while formatting my deskop i found that smell comming from my deskop
what should i do with it.
moinabrar
Junior Member level 2
check ur motherboard.. and smps wires.!!
mister_rf
Advanced Member level 5
Romania
Start by carefully inspecting the capacitors on the motherboard. Capacitors are at great risk for failure. (It's possible like one of them is opening up). Make sure you don't have any stuck cooling fan. Check the 20/24 pins ATX main power supply connector. You may chase out all of the PSU wiring for short-circuits/bad connections. Many times when the smoke escapes it generally leaves a mark. Did you see the mark?
If all motherboard components/connectors/cables are OK so it’s probably a bad power supply unit... Replace with a new one.
