hai how it works it is intresting
grittinjames
Advanced Member level 1
bangalore india
hai this is a application circuit i am not getting how this transistor getting off
plz tell me
Eugen_E
Full Member level 6
Romania
It is well explained in the application note, with details and scope image.
grittinjames
bangalore india
hello bai ,look it properly once
base voltage given to transister is suffecient to turn on it , even though it is not in saturation, once it become on due to +ve feedback winding it will take to saturation.when core become saturate ur feed back winding vtg also become 0, but still to make transister fully off some -ve vtg is required to apply to base , how this vtg will induce to feedback winding
A.Anand Srinivasan
Advanced Member level 5
India
when the inductor W1 saturates it means that all the energy is stored in the form of magnetic energy and this means no current or very less current which is not enough to drive the transistor and hence the transistor turns off...
grittinjames
bangalore india
thanks for respond Mr Anand
but initialy tranistor turned on with the help of this same voltage
that means base vtge applied is good enogh to make transistor on , other wise oscillation will not start at all,
then i am coming to ur conclusion
as per u transistor turn off due to less current , then how it turn on for next cycle ?
ha ha
realy funny
A.Anand Srinivasan
India
when the transistor turns off the other inductor W2 magnetic field collapses which makes W1 magnetic field collapsing which results in current drive to the transistor which then turns it on and after sometime saturation occurs and transistor turns off... this continues....
grittinjames
bangalore india
i think ur explanation is not right ,
there is some negative voltage shuld induce in feedback winding to turn off trasister fully
how it will generate
A.Anand Srinivasan
India
dude the inductor is a reactive component and once it starts saturating the current through it starts dropping... for a inductor V=L(di/dt) and hence when the current starts reducing di/dt becomes negative and the voltage across the inductor starts becoming negative.... so the transistor turns off...
hope it is useful....
grittinjames
bangalore india
bai once inducter get saturate current is not getting drop it will be maximum as per my knowledge
but due to no change in current induction will happen to cuppled inducter
petergay38
Newbie level 1
Dear Sir, Can somebody help with a Class D high
power Circuit Digram About 1000 Watts into 8 omhs
as I like to build one to use in my Band,I really cant
afford to buy one. Thanking You.
Peter Gay.
my Email address.peter.gay@gmail.com
A.Anand Srinivasan
India
dude when W2 saturates there is no feedback to W1 since the current in W2 is constant and hence the current through W1 starts dropping and this would lead to a negative voltage....
    grittinjames
