I14R10
Full Member level 3
I built H-bridge with MJE2955 and MJE3055 using this schematics **broken link removed**. It works, kind of. The motor spins one way and other way as it should be. The problem is that the voltage across the motor is only 1V. This H bridge is powered from 9V supply. And along with that problem, the transistors really heat up. When I measure the voltage across the power supply, it's also 1V, so I suspect there is a short circuit. But I can't find it after few hours of experimenting. I'm almost ready to give up and go with relays. Is there a mistake in that schematics?
