I have designed and implemented one phase inverter using SPWM technique, IR2110, IRF840, Atmega32.
I have faced a problem. I have tested the control section (I left the power section open), it works quite well. But when I connect the DC voltage (power section) to the circuit, SPWM on Mosfet gates signals don't work properly and it drops. Circuit sheet as well as a video attached here.
15 Volt voltage is used to drive Mosfets. When I connect the DC power to the circuit, Voltage "G0 N1" and "G2 N2" drop from 15 to 5 volts and circuit doesnt work properly. please see the video. Anyone can suggest anything? I appreciate your help.
