gvim color scheme for verilog coding
krishanu007
Member level 2
Member level 2
Bangalore,India
Hi people,
can you suggest any good color scheme for verilog coding :lol: ,with good syntax highlighting & dark background.
I am currently using the inbuilt elford ,but its straining my eyes a little.
& if possible for C also.:-?
you can set gvim background color using inbuilt syntax , you need to create .gvimrc file , and put those commands inside that file so that everytime you open gvim , your setting will be sourced.
I normally used zellner which having light background and each syntax clearly visible.
Desert colr scheme is good. You can turn on syntax. N lot more options in above link.
Posted via Topify on Android
