bluethunder7000
Member level 2
dspic33f ethernet
Hi
First, I would like to illustrate the main subject of my issue. I am preparing a project using dsPIC33F; I bought the board from mikroelektronika and bought some other extra boards including the ENC28J60.
I need to send data between my laptop and the dsPIC33F board using Ethernet communication link.
I spent around three weeks to read and understand the operation of the Ethernet module ENC28J60, dsPIC33F and some protocols like TCP/IP.
The main problem I have, that i don't know where is the correct beginning to send data between ENC28J60 and dsPIC33F in correct way.
Also, I didn't found any complete project on the internet to take it as a guide for me.
I am using the Mikro C complier and the data which I need to transmit is values (Numbers Only).
Now I would like to find some help to put me on the right way for this issue or some complete project in C can use it as a guide plus i would like to know the required program which I have to use it on laptop to receive the data from the dsPIC33F boards
BR
Hi
BR
