guide for installation of IC5141 USR5 on RHEL 5.1
hock
Advanced Member level 2
India
ic5141 install
i have succeeded in installing IC5141 USR5 on RHEL 5.1 and Scientific Linux in 64 bit mode from the original cd media without any modification to the installation script of ic5141.
this is how i have done. it is very lengthy and hence i am calling it dummy's installation guide. the reapply or inputs are in bold.
hock
1) Install rhel 5.1 or Scientific Linux 5.1 (64 bit preferred)
2) Extract ic5141 USR5 in /tmp/IC5141USR5_lnx86.Update/CDROM1 to CDROM4
3) Extract ic5141 BASE in /tmp/IC5141_lnx86.Base/CDROM1 to CDROM3
4) Install ncompress-4.2.4-33.i386.rpm by using command "rpm -ivh ncompress-4.2.4-33.i386.rpm"
5) Install tar-1.13.25-2U80_1cl.i386.rpm by using command "rpm -Uvh --oldpackage tar-1.13.25-
2U80_1cl.i386.rpm"
6) Open a c shell command terminal in /tmp/IC5141USR5_lnx86.Update
7) Set posix compliance by typing "export _POSIX2_VERSION='199209'" in the above terminal
Cool Type "CDROM1/SETUP.SH" to start installation
9) Specify installation path as "/opt/cadence/ic5141". when asked say "Y" for creating the destination
folders
You will get following message screen
Do you want to start softload? [y/n]: y
Warning: Software administration should not be done as root
because it could cause file permissions problems while
extracting software
Press [Return] to proceed, q to quit : (return)
-------------------MAIN MENU----------------------
The available options are:
1) Load Available Products
2) List Installed Products
3) Remove Installed Products
4) (unavailable option) Configure Installed Products
5) (unavailable option) Test Installed Products
6) Update Installed Products
h) Help
q) Quit
Type your choice: [ 1 ]1
CD#1 of the media set being used is required.
You must now identify where the CD-ROM is mounted.
1) Local (mounted to this machine)
2) Remote (mounted to another machine)
m) Main Menu
h) Help
Type your choice: [ 1 ] 1
Next You will get following message screen
Specify the CD-ROM mount point
1) /cdrom
2) Other
m) Main Menu
p) Previous Menu
h) Help
Type your choice: [ 2 ]2
Type the CD-ROM mount point: [ /tmp/cadence/IC5141USR5_lnx86.Update/CDROM1 ]
Extracting installation information from CD#1.
Do you want to view the README file?
Please press y (yes) or n (no) : y
Where is the installation information?
1) (unavailable option) Work Order
2) E-mail File
3) Tape
4) Cadence Catalog
5) Documentation Catalog
h) Help
p) Previous Menu
q) Quit
Type your choice: [ 2 ] 4
Next screen will ask you to select the products. Alwase select all the products. Do not try to save
some disk space. You do not know which product needs which additional tool.
a) All of the above
n) None of the above
p) Previous Menu
Type your choice (a,n,p,1-3,2 5 9 ...): a
Are your selections correct? [y/n] y
The following media is required:
IC5141 lnx86 P/N 356-70352-0501 CDROM # 1
IC5141 lnx86 P/N 356-70352-0502 CDROM # 2
IC5141 lnx86 P/N 356-70352-0503 CDROM # 3
IC5141 lnx86 ISR 200706221130 CDROM # 1
IC5141 lnx86 ISR 200706221130 CDROM # 2
IC5141 lnx86 ISR 200706221130 CDROM # 3
IC5141 lnx86 ISR 200706221130 CDROM # 4
Checking IC5141 lnx86 P/N 356-70352-0501 CDROM # 1 ...
Mount IC5141 lnx86 P/N 356-70352-0501 CDROM # 1 .
This CD-ROM is IC5141 lnx86 ISR 200706221130 CDROM # 1 .
The setup will start installing cadence ic 5141 usr5. After some time it will ask for base package of ic5141.
You should see following message on your screen
Your package selections require IC5141 lnx86 P/N 356-70352-0501 CDROM # 1.
1) Mount IC5141 lnx86 P/N 356-70352-0501 CDROM # 1 on
and install packages contained on it.
2) Skip IC5141 lnx86 P/N 356-70352-0501 CDROM # 1 and
proceed with the installation.
is NOT available at this time.
3) IC5141 lnx86 P/N 356-70352-0501 CDROM # 1 already mounted on
/tmp/cadence/IC5141USR5_lnx86.Update/CDROM1, continue.
4) Change CD-ROM mount point.
m) Main Menu
Type your choice: 4
m) Main Menu
h) Help
1) /cdrom
2) Other
m) Main Menu
p) Previous Menu
h) Help
Type your choice: [ 2 ] 2
Now specify the following mount point
/tmp/cadence/IC5141_lnx86.Base/CDROM1
You should see the setup to continue forward again.
loading edif300userDoc05.10-p002 ......................................
Installation of edif300userDoc05.10-p002 complete
Total Installation 100 % done
Checking the installed products...
Updating status of installed products...
Cleaning up...
The products you selected have now been loaded.
Continue the installation by configuring the products you just loaded.
CONFIGURATION IS NOW REQUIRED for products using OpenAccess version
2.2 and later. For more information, refer to the release README file
found on the top level of the CDROM.
Check the ~install/tmp/install.history file for the list of products
affected by this install.
Now you should see the menu screen again.
4) Configure Installed Products
h) Help
q) Quit
Type your choice: [ 1 ] 2
Next screen will ask you to specify the os
Specify the operating system of the products:
No. Operating system
1) Solaris Operating System (sun4v)
2) Linux Operating System (lnx86)
3) Itanium Linux Operating System (lni64)
4) HP-UX Operating System (hppa)
5) IBM AIX Operating System (ibmrs)
Type your choice [ 1 - 5 ]:2
After sometime you should see the menu screen again
h) Help
q) Quit
Type your choice: [ 1 ]4
This will bring up the config menu
-------------CONFIGURATION INFORMATION MENU---------------
Select one of the following:
1) System-level Configuration
2) User-level Configuration
m) Main Menu
h) Help
It will now ask you for list of installed options
a) All of the above
Nest you should see the following screen
Preparing to configure the Stream Manager tool now...
This release includes a copy of the Stream Manager tool and associated data
files which help you to set up and manage your run-time environment.
For details of the tool refer to the Stream Manager documentation which is
included in the documentation set for this release.
For details of the Stream Manager configuration process, see
/opt/cadence/ic5141/tools.lnx86/stream_mgt/install/config.txt
You have the choice whether to configure the Stream Manager now or at a later
date. If you choose to do it later, you can either run Softload configuration
again, or type
/opt/cadence/ic5141/tools.lnx86/stream_mgt/install/install
Do you want to configure the Stream Manager now? (y/n) : y
Configuring Stream Manager - Wed Nov 14 20:48:48 IST 2007
Installing Stream Manager tools.
Enter full network path name of required installation directory
(<CR> = /opt/cadence/smTool03.00-s009) :
again, or type
Creating /optcadence/smTool03.00-s009
Copying Stream Manager and associated tools to /opt/cadence/smTool03.00-s009
- this may take a few minutes.
/opt/cadence/smTool03.00-s009/tools/jre/bin/java: error while loading shared libraries:
libpthread.so.0: cannot open shared object file: No such file or directory
I get this error message. Can Some one solve this error? The software is working fine.
Changing perl references to suit local installation
Using perl from the install directory
/opt/cadence/smTool03.00-s009/tools.lnx86/perl-5.8.8
Locating java installation.....
Using java from the install directory
/opt/cadence/smTool03.00-s009/tools.lnx86/jre
Locating a central Cadence registry.
The Cadence registry is a read-only registry which contains Product and
Stream template data supplied by Cadence. The Softload system configuration
step populates this registry over time.
Cannot locate an existing Cadence registry root directory through the
CDS_REGISTRY_ROOT environment variable or in the default location
/opt/cadence/smCdsReg.
Enter full network path name for Cadence registry root directory
(<CR> = /opt/cadence/smCdsReg) :
Creating /opt/cadence/smCdsReg
Locating a local registry
The local registry contains site specific registry data. The registry
is populated over time as part of the stream and project registration
process, or as details of third party products are added.
The Cadence and local registries cannot share the same location.
Cannot locate an existing local registry root directory through the
LOCAL_REGISTRY_ROOT environment variable or in the default location
/opt/cadence/smLocal.
Enter full network path name for local registry root directory
(<CR> = /opt/cadence/smLocal) :
Creating local registry /opt/cadence/smLocal
Creating setup files
Setup commands are available in
/opt/cadence/smTool03.00-s009/tools.lnx86/stream_mgt/install/setup.csh
and
/opt/cadence/smTool03.00-s009/tools.lnx86/stream_mgt/install/setup.sh.
Updating Cadence registry data in /opt/cadence/smCdsReg.
Creating ./Streams/Templates/lnx86/IC5141
Creating ./Products/lnx86/Diva/5.1.reg
Creating ./Products/lnx86/Spectre/5.1.reg
Creating ./Products/lnx86/AMS_Designer/5.1.reg
Creating ./Products/lnx86/Virtuoso_Composer/5.1.reg
Creating ./Products/lnx86/Analog_Design_Environment/5.1.reg
Creating ./Products/lnx86/Virtuoso_Layout_Migrate/5.1.reg
Creating ./Products/lnx86/Virtuoso_XL_Layout_Editor/5.1.reg
Creating ./Products/lnx86/MMSim/5.3.reg
Creating ./Products/lnx86/Virtuoso_Preview/5.1.reg
Creating ./Products/lnx86/VoltageStorm/4.1.reg
Creating ./Products/lnx86/Dracula/4.9.reg
Creating ./Products/lnx86/Spectre_RF/5.1.reg
Creating ./Products/lnx86/Virtuoso_Chip_Editor/5.1.reg
Creating ./Products/lnx86/Virtuoso_Layout_Editor/5.1.reg
Creating ./Products/lnx86/IC_Reliability/4.1.reg
Configuration completed.
Proceeding with configuration of lfvhdComp
Synergy users must install these libraries
Install Valid library and Sim primitives? (<cr> = n): y
Install XL library and Gate primitives? (<cr> = n): y
Installing Leapfrog Analyzer and Design library...
Library installation...
vrelocate 2.85-a002: (c) Copyright 1992-1997, Cadence Design Systems, Inc.
Installation of Leapfrog Analyzer and Design libraries complete
Prepare libraries for AMS Designer
1) Add an IUS installation directory to path
2) Quit
This you can use to setup your AMS lib.
This is the end of cadence IC5141 usr5 setup.
Use the attached start-up file to load cadence.
ic5141 installation
Dear Hock,
May you kindly specify your HW configuration ?
Like what brand/model of your MB, Graphics card ...?
Thanks,
sunjimmy
cadence ic5141 installation
Core 2Deo 2.6GHz, intel G965RY motherboard and on board aAGP.
but this is irrelevent. you need not worry about ur hardware. if you can install rhel or scientific linux 5.1 u are ready to install cadence.
hock
how to install cadence ic5141
Hi HOCK,
I am getting problem wheile installing RHEL4 on my laptop it is sony vaio-NR series it has a toshiba hardisk and it is not detected by RHEL-4
can you let me what can be done to get is installed.
centos-5.3 ic5141
use scientific linux 5.1. it is available for free. it detects ur laptop as well.
hock
ic5141 usr5
I download the base version and got is installed on my SUSE OS..
everything went fine even i checked by using the installed products option and come to know.
now the problem is that i need to install the licence configuration utility and when i run the setup file it asks for installing the installscape. When i say yes it starts initializing but gives a error later as below
java: xcb_xlib.c:52:xcb_xlib_unlock: Assertion 'c->xlib.lock' failed. Aborted
1) how to install the license utility.
2) how to run the installed products because i m new to this type of operating system.
ic5141 rhel5
log in as root and then delete the .lock files from user account.
you have crashed the license manager while using it, some files are in lock state.
hock
ic5141 root install
should caused by LD_ASSUME_KERNEL statement
hiding in the code
centos 5.3 ic5141
I could install cadence ic 5141 on RHEL 4, I also could install it on RHEL 5.2 but I have an error about glibc2.0, If you want to us cadence in RHEL5.2 you must to uninstall its glibc2.0 and install an older version of it on RHEL5.2 ;)
rhel 5 ic5141
Hi, i've install Scientific Linux 5.2 on VM and then IC5141, but i get the GLIBC error when i try to run icfb. With LD_ASSUME_KERNEL i don't have solved the issue. Is it possible that's my version of IC5141 is too old (i.e USR3) ?
ic5141 sun4v isr
use usr5 and above. they are compatible with kernel 2.6
hock
rhel5 install ic5141 error
Thanks Hock, I've got only the license for IC5033 and i didn't find USR5 in the "network".
ic5141)usr5
this is amazing, rarely did I found people are patient enough to write down towhole procedures
configuration of lfvhdcomp
i have done it so that others can benefit out of it. most of the users on this forum are college kids who do not know system admin and cadence installation.
it was successfully done at a time when cadence was advising a tar ball option from old machines. i do not know if they still know how to do it.
glad that you think it is useful.
hock
cadence ic5141 configuration
Hi hock ,
thanks a lot for the procedure, i followed the same and got IC5141 installed on RHEL 4 ( after fighting for a long time ) one of my friend helped me to set up RHEL on my pc.
1) Now my problem is to understand your last sentence
"Use the attached start-up file to load cadence"
Since i am new to linux i dont know what you mean and how to use the start up file.
2) i would also like to know the procedure to install the license file.
3) how to run the application. since i am windows user, windows creates icons and we have to simply click. what i understand about linux is that we hav to execute the BIN files now how to do that and which file.
It will be very help ful if you can let me know the procedure..
thanxxxx
kumar
ic5141 libpthread
for 1 copy the file to your home directory.
use the command "source startup_file_name"
2) the bashrc or cshrc file contains the location of license. the variable CDS_LICENSE_FILE points to the license file. if your license file is located at \opt\cadence\license.dat
then
export CDS_LIC_FILE=/opt/cadence/license.dat
export LM_LICENSE_FILE=/opt/cadence/license.dat
open a command windows in bsh
type source ic5141_cshrc
type lmgrd-c /opt/cadence/license.dat
you should see the licenses.
icfb &
hock
cadence installation guide redhat 4
This should be called paper:)
I installed IC5141 in openSUSE 10.2 enviroment, but when i invoked icfb, glibc error happen. I will updae IC5141 and try it again.
BTW, thanks the good report!
installing ic5141 usr5 on redhat enterprise linux
what is the good news?
hock
