Jester
Full Member level 6
- Joined
- Aug 18, 2012
- Messages
- 377
- Helped
- 7
- Reputation
- 14
- Reaction score
- 7
- Trophy points
- 1,298
- Location
- Activity points
- 4,754
I'm doing a 2 layer PCB with a somewhat sensitive analog circuit using a LTC1966 RMS converter. The data sheet emphasizes that the output signal from the converter should be surrounded with a guard ring. In the data sheet example the destination IC has a ground pin adjacent to the signal input pin, however the closest ground pin on the destination IC I'm using is two over from the input pin (see schematic below). So there is another signal within the guard ring, is this okay?
In the sketch I "painted":
Bottom of board is also a ground plane
Does this look okay?
the sensitive signal pink (actual top layer)
the ground ring green (also top layer)
