#include <p18f4220.h>
#include <delays.h>
#pragma config OSC = HS
#pragma config WDT = OFF
#pragma config LVP = OFF
void SendLCD(unsigned char Byte, unsigned char type); //send byte to print on LCD screen
#define LCD LATD //LCD Latch PORT
#define LCD_RS LATEbits.LATE0 //Register Select (0: Instruction/ 1: Data)
#define LCD_E LATEbits.LATE2 //Enable (Starts data read/write)
unsigned char
//GSM byte receiving variables
GSM_Byte_1 = 0,
GSM_Byte_2 = 0;
void main(void)
ADCON1 = 0x0F; //SET ALL PORTS as DIGITAL I/O
PORTC = 0; //intialize PORTC
TRISCbits.TRISC6 = 0; //Serial TX
TRISCbits.TRISC7 = 1; //Serial RX
PORTD = 0; //initiallize PORTD
TRISD = 0x00; //LCD output
PORTE = 0; //initiallize PORTE
TRISEbits.TRISE0 = 0; //LCD Register Select (to LCD Pin 4)
TRISEbits.TRISE2 = 0; //LCD Enable (to LCD Pin 6)
//Configuring below the USART
TXSTAbits.TX9 = 0; //8bit transmission
TXSTAbits.TXEN = 1; //transmit enabled
TXSTAbits.SYNC = 0; //async mode
TXSTAbits.BRGH = 1; //high speed
TXSTAbits.TRMT = 1; //TSR empty
SPBRG = 129; // 9.6kbs baud rate at 20Mhz
RCSTAbits.SPEN = 1; //enable serial port
PIE1bits.RCIE = 1; //enable interrupt upon reception
RCSTAbits.RX9 = 0; //8bit reception
RCSTAbits.CREN = 1; //enable continous receive
RCSTAbits.ADDEN = 0; //dissable address detection (9bit)
INTCON = 0; //Disable all interrupts
Delay10KTCYx(50); //100ms wait for LCD power up
//Initialize the LCD
LCD = 0x00; //clear LCD PORTD pins
Delay1KTCYx(25); //delay 5mS
SendLCD(0x03,0); //Initialization command
Delay100TCYx(8); //delay 160uS
SendLCD(0x3C,0); //Interface lenght is 8 bits long, 2-lines, 5x10 dots
SendLCD(0x10,0); //Turn off LCD
SendLCD(0x01,0); //Clear LCD
SendLCD(0x06,0); //Increment the cursor after each byte written
SendLCD(0x0C,0); //Turn on LCD, cursor off, cursor blinking off
//Start up Delay
Delay10KTCYx(250); //500ms delay
//Sending out 'Set FACTORY DEFAULT' Command to GSM Modem
TXREG = 'A';
while(TXSTAbits.TRMT==0); //wait until transmition is complete
TXREG = 'T';
TXREG = '&';
TXREG = 'F';
TXREG = '[';
TXREG = '0';
TXREG = ']';
while(PIR1bits.RCIF == 0); //wait for data reply from GSM Modem
GSM_Byte_1 = RCREG; //reading RCREG clears RCIF
GSM_Byte_2 = RCREG; //reading RCREG clears RCIF
//Converting GSM data bytes to ASCII for LCD display
GSM_Byte_1 += '0';
GSM_Byte_2 += '0';
SendLCD(0x80,0); //activate LCD line 1
//Display GSM acknowledgement 'OK' on LCD
SendLCD(GSM_Byte_1,1);
SendLCD(GSM_Byte_2,1);
while(1); //loop forever
}//end of main()
LCD_RS = type; //Set whether it is a Command (0) or Data/Char (1)
LCD = Byte; //assign the new data to the LCD PORTD
LCD_E = 1; //Set Enable High
LCD_E = 0; //Set Enable Low
}//end of SendLCD()
