#include<reg51.h>
#include<lcd.h>
#include<uart.h>
#define robot P2
void main()
unsigned char temp,i,j,k,l,m;
unsigned char read[8],a[8]="forward ",b[8]="backward",c[8]="left ",d[8]="right ";
lcd_init();
uart_init();
robot = 0;
lcd_stringxy(0,0,"GSM Controlled");
lcd_stringxy(1,0,"Robot");
while(1)
j=0,l=0,m=0;
while(rx_data()!=0x0d);
while(rx_data()!=0x0a);
if(rx_data()=='+')
if(rx_data()=='C')
if(rx_data()=='M')
if(rx_data()=='T')
if(rx_data()=='I')
while(rx_data()!=',');
temp=rx_data();
delay_ms(10);
tx_string("at");
tx_data(0x0d);
tx_data(0x0a);
tx_string("at+cmgf=1");
tx_data(0x0d);
tx_data(0x0a);
tx_string("at+cmgr=");
tx_data(temp);
tx_data(0x0d);
tx_data(0x0a);
for(i=0;i<8;i++)
read[i]=rx_data();
lcd_cmd(0xc0);
for(i=0;i<8;i++)
lcd_data(read[i]);
for(i=0;i<8;i++)
if(read[i]==a[i])
j++;
if(read[i]==b[i])
k++;
if(read[i]==c[i])
l++;
if(read[i]==d[i])
m++;
if(j==8)
robot=0x0a;
if(k==8)
robot=0x05;
if(l==8)
robot=0x02;
if(m==8)
robot=0x08;
REG51.H
Header file for generic 80C51 and 80C31 microcontroller.
Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
All rights reserved.
#ifndef __REG51_H__
#define __REG51_H__
/* BYTE Register */
sfr P0 = 0x80;
sfr P1 = 0x90;
sfr P2 = 0xA0;
sfr P3 = 0xB0;
sfr PSW = 0xD0;
sfr ACC = 0xE0;
sfr B = 0xF0;
sfr SP = 0x81;
sfr DPL = 0x82;
sfr DPH = 0x83;
sfr PCON = 0x87;
sfr TCON = 0x88;
sfr TMOD = 0x89;
sfr TL0 = 0x8A;
sfr TL1 = 0x8B;
sfr TH0 = 0x8C;
sfr TH1 = 0x8D;
sfr IE = 0xA8;
sfr IP = 0xB8;
sfr SCON = 0x98;
sfr SBUF = 0x99;
/* BIT Register */
/* PSW */
sbit CY = 0xD7;
sbit AC = 0xD6;
sbit F0 = 0xD5;
sbit RS1 = 0xD4;
sbit RS0 = 0xD3;
sbit OV = 0xD2;
sbit P = 0xD0;
/* TCON */
sbit TF1 = 0x8F;
sbit TR1 = 0x8E;
sbit TF0 = 0x8D;
sbit TR0 = 0x8C;
sbit IE1 = 0x8B;
sbit IT1 = 0x8A;
sbit IE0 = 0x89;
sbit IT0 = 0x88;
/* IE */
sbit EA = 0xAF;
sbit ES = 0xAC;
sbit ET1 = 0xAB;
sbit EX1 = 0xAA;
sbit ET0 = 0xA9;
sbit EX0 = 0xA8;
/* IP */
sbit PS = 0xBC;
sbit PT1 = 0xBB;
sbit PX1 = 0xBA;
sbit PT0 = 0xB9;
sbit PX0 = 0xB8;
/* P3 */
sbit RD = 0xB7;
sbit WR = 0xB6;
sbit T1 = 0xB5;
sbit T0 = 0xB4;
sbit INT1 = 0xB3;
sbit INT0 = 0xB2;
sbit TXD = 0xB1;
sbit RXD = 0xB0;
/* SCON */
sbit SM0 = 0x9F;
sbit SM1 = 0x9E;
sbit SM2 = 0x9D;
sbit REN = 0x9C;
sbit TB8 = 0x9B;
sbit RB8 = 0x9A;
sbit TI = 0x99;
sbit RI = 0x98;
#endif
//NOTES:
//1: This code may be distributed and modified freely .
//2: External Crystal of 11.0592 MHz is assumed.
//3. 16x2 lcd Modules is being operated in Nibble Mode.
//4: Connections to the lcd are assumed as followed:
// RS -> P1.0
// RW -> P1.1
// E -> P1.2
// D4,D5,D6,D7 -> P1.4,P1.5,P1.6,P1.7
#define lcd_DATA P1
sbit lcd_rs = P1^0;
sbit lcd_rw = P1^1; //Must Always be low to allow data to be sent to lcd
sbit lcd_en = P1^2;
void delay_ms(unsigned int n)
int i,j;
for(i=0;i<n;i++)
for(j=0;j<124;j++);
void lcd_enable()
lcd_en = 1; //High to low transition
delay_ms(5);
lcd_en = 0;
void lcd_cmd(unsigned char cmd)
lcd_rs = 0; //cmd Mode
lcd_DATA = ((cmd & 0xF0)|0x04);
lcd_enable();
lcd_DATA = (((cmd<<4) & 0xF0)|0x04);
lcd_enable();
delay_ms(5);
void lcd_data(unsigned char ascii)
lcd_rs = 1; //Data Mode
lcd_DATA = ((ascii & 0xF0)|0x05);
lcd_enable();
lcd_DATA = (((ascii<<4) & 0xF0)|0x05);
lcd_enable();
delay_ms(5);
void lcd_init()
lcd_cmd(0x02); //Enable 4 bit mode
lcd_cmd(0x28); //Set interface 4 bit 2 line
lcd_cmd(0x08); //Enable display/cursor
lcd_cmd(0x06); //Set cursor move, Move cursor right
lcd_cmd(0X0C); //Turn on display
void lcd_gotoxy(unsigned char row,unsigned char column) //move cursor to the specified position
if(row==0)
lcd_cmd(0x80+column);
else if(row==1)
lcd_cmd(0xC0+column);
void lcd_number(int val,unsigned int field_length) // Function to display number
char str[5]={0,0,0,0,0};
int i=4,j=0;
while(val)
str[i]=val%10;
val=val/10;
i--;
if(field_length==-1)
while(str[j]==0) j++;
else
j=5-field_length;
if(val<0) lcd_data('-');
for(i=j;i<5;i++)
lcd_data(48+str[i]);
void lcd_string(unsigned char *str)
while(*str!='\0') //Till null character is encountered
lcd_data(*str);
str++;
void lcd_stringxy(unsigned char row, unsigned char col, unsigned char *lcd_string)
lcd_gotoxy(row,col);
while (*lcd_string)
lcd_data(*lcd_string++);
void lcd_numberxy(unsigned char row, unsigned char col,int val,unsigned int field_length)
int i=4,j=0;
while(val)
str[i]=val%10;
val=val/10;
i--;
else
j=5-field_length;
for(i=j;i<5;i++)
void uart_init(void) // INITIALIZE SERIAL PORT
TMOD = 0x20; // Timer 1 IN MODE 2-AUTO RELOAD TO GENERATE BAUD RATE
TH1 = 0xFD; // LOAD BAUDRATE TO TIMER REGISTER
SCON = 0x50; // SERIAL MODE 1, 8-DATA BIT 1-START BIT, 1-STOP BIT, REN ENABLED
TR1 = 1; // START TIMER
void tx_data(unsigned char serialdata)
SBUF = serialdata; // LOAD DATA TO SERIAL BUFFER REGISTER
while(TI == 0); // WAIT UNTIL TRANSMISSION TO COMPLETE
TI = 0; // CLEAR TRANSMISSION INTERRUPT FLAG
unsigned rx_data(void)
while(RI == 0); // WAIT UNTIL DATA IS RECEIVED
RI = 0; // CLEAR FLAG
return SBUF; // RETURN SERIAL DATA
void tx_string(unsigned char *str)
while(*str)
tx_data(*str);
str++;
// END OF PROGRAM
temp=rx_data();
i have checked my gsm modem giving commands from hyperterminal it is working, but when i use a microcontroller it is not reading the message what i send from other mobile.
