Weylin
Newbie level 6
- Joined
- Sep 19, 2012
- Messages
- 14
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,408
I notice that a lot of circuit simulations throw a fit if no ground terminal is found.
Why is this? Wouldn't a closed circuit with a two terminal voltage source and a proper load be enough?
Not all devices have a ground to connect to, such as a portable radio. What I do, and I'm unsure if this is accurate, is I put a very high value resistor between the ground and the rest of the circuit.
Does this properly simulate such a circuit and act as the interface between the circuit and surrounding air?
I'm really not sure what the point of a ground symbol is unless you're using one terminal voltage rails, modeling a 3 pronged outlet, or don't want to have a thousand vertical lines on your schematic plunging through everything to connect to the return line (or source line if you visualize electron flow )
