jmb22
Newbie level 2
I am trying to get simulation of the magnetic field behaviour for a grounded coplanar waveguide. I am using HFSS for 3 days now. And my only success has been to install the software.
Basically, I designed the GCPW using 2 wave ports. However, I can't get an output that makes sense. I calculated the width and gap to get impedance match to 50Ohms using TXLine.
First, how do you define the 3 ground planes as "ground plane". Basically, they are not really plane but rather box so I can't use the option of HFSS.
I am not interested to generate specific mode in GCPW except a quasi TEM mode. I am planning to use the GCPW as a broadband transmission line (5GHz to 40GHz)
Second: should I define any mesh operations?
Also, if the rectangle that defines the Wave ports are such that they are connecting the central line, the 2 ground planes on top of the substrate and the ground plane on the bottom, then I obtained the follwoing:
[error] Port refinement, process abc3d died unexpectedly.
My question: WHY?
If I adjust the ports so they are only connected to the top metallic layers, then it "works": no error message.
However, the direction of H field lines and the amplitude do not make sense?
Thanx for your help.
My question: WHY?
