luck09
Newbie level 5
Hi all,
I am trying to control a stepper motor with L298. I have a question about GND pin.
L298 has two voltage supply pins for power and signal. But it has only one GND pin. So I suppose that the GND pin is common between power voltage and siganl voltage here. If I am using two external voltage for L298. One from a power supply, one from a Pin of microcontroller. Power supply has two pins, one is GND. So does the microcontroller. How should I connect the GND pin of power supple and GND pin of microcontroller to the GND pin of L298? Or should I connect three GND pins to be common? Does it affect the circuit?
Thank you very much!
