graduation elevator project
suhail iskndrany
Newbie level 3
I have a 3 floor elevator project with level sensors(limit switch) on every of them and 3 pushbuttons (one for first, one for second and one for third floor) outside the door.
I built a prototype
i will use pic microcontroller
PIC 16F874A/877A
to control elevator
I need the basic programm (to go up/down/stop where ordered) using Pic C Compiler.
can you help me???plzzzzzzz
this part is not of my spiciliest
it was for my ex-partner & I have no time to lern programming
the programing is part of the project but not all
---------- Post added at 15:06 ---------- Previous post was at 14:56 ----------
my job is to integrate embeded system not to program
they lern us just to program motorola
I didn't know how to program pic
hi,
this code is for my elevator project (using using pic c)
[ 3 floors with 3 pushbuttom & 3 limit switches] al are outside.
but ther is aproblem, that u should keep pressing on pushbuttom to order the elevator room...
any advices?????
thanks in advance
//////////////////Initiliziation///////////////////////
#include <16f877a.h>
#fuses hs,NOWDT
#use delay(clock=8000000)
#bit t1_overflow=0x0C.0
set_tris_b(0b11111111);//define port B as input port
set_tris_c(0b11111111);//define port C as input port
/////////////////////Main Program///////////////////////////////////
void main() {
int Sensor;
int Order;
start:
Order= input_C();
Sensor= input_B();
if (Order==Sensor)
output_low(PIN_a0);
output_low(PIN_a1);
goto start;
else if(Sensor > Order)
output_high(PIN_a0);
output_low(PIN_a1);
else
output_high(PIN_a1);
output_low(PIN_a0);
