GPRS and PPP with PIC16/PIC18
branek
Junior Member level 3
SERBIA
pic18 gprs
Hello
Could anyone help me with GPRS and PPP protokol? Last 5 hours I am on this board and internet, read almost any document about GPRS and nothing... So, am I stupid or what? :oops:
I tryed many TCP stack, but no lucky with GPRS! I think that GPRS need CHAP, not PAP, and that is point where I am stucked! I try that with uChip source from APPNOTE 724. But there is only PAP... And after starting of PPP, I get some packets exchanged, and on end: NO CARRIER. The step where i get NO CARRIER is when I sending username and password.
If someone know source for gprs and PPP that is WORKING, please point me! And also if you can help me on any other way, do not shy...
I can try it with NOKIA 6100, and also with siemens M50/ M55, and with any PIC.
Thanx in advance... and sorry for my english
mrcube_ns
Advanced Member level 1
Europe
pic18 ppp
For this purpose I use GPRS modem with build in TCP stack (Enfora Speeder), so you dont need to think about TCP stack, or PPP.
Just configure modem(s) and futher on do nothing more than plain serial communication.
Regards.
Mr.Cube
gorkin
brazil
ppp pic18f
Hi Mr. Branek!
At moment I develop one application with Siemens MC35i GSM module and PIC18 microcontroller.
I am prettend port the following stack:
www.opentcp.com
In no longer past, I read that one brazilian group port the uTCP stack for embedded environment, but I not found more informations...if You are interested, visit the Adam´s page:
https://www.dunkels.com/adam/
Gorkin.
techie
Advanced Member level 3
Pakistan
gprs stack pic18
GPRS needs no authentication. THis is becuase billing is inside the SIM.
SO when the modem asks for authentication, you just ignore it and proceed to the next step.
pisoiu
Romania
ppp gprs sim
As far as I know, this may be valid for some networks. It all depends on the operator. Some networks request this authentication procedure. The most common case I saw is that you can enter any crap you want in user name and password field, because the data are ignored (indeed the real authentication is based on SIM data), however the procedure must be performed.
/pisoiu
