arya.jagadeesh
gm is decreasing in simple ckt ..where i am applying vds=1 and changing gate voltage from 0 to 1.8 vt=.4..after entering triode equation says independent....but it is decreasing ...why
Hi Aryagm is decreasing in simple ckt ..where i am applying vds=1 and changing gate voltage from 0 to 1.8 vt=.4..after entering triode equation says independent....but it is decreasing ...why
Hi Arya
May i saw your just SIMPLE CKT ? how do you expect i know what is in your mind and expect help ? shall we be oracles here ?
Best Wishes
Goldsmith
What kind of nmos ? i hope you know it is important to know the part number which you've used because threshold and on state voltage and IDSS and ... of every mosfet is different in compare with the other ones . WHEN YOU WANT ASK A QUESTION FIRST GIVE FULL INFORMATION OF YOUR QUESTION ! ok ?for nmos transistor
