Glove based key board
dsk2858
Member level 2
Chennai,India
sir
i need to design a glove, with a combination of SIX inputs to include the entire keyboard on the glove.
when i press a combination like
D6 D5 D4 D3 D2 D1 D0
0 0 0 0 0 0 1 - A
0 0 0 0 0 1 0 - B
SO ON
which statements should i use in C-language to complete my project.
sir please give an example of codes as i am biggner to programming
i am using ATmega32 MCU and need to transfer that values to computer with serial interface.
The part that isn't so obvious is that your program will be in an idle loop (or executing other routines) waiting for a finger to press a switch.
Then as soon as a switch press is detected, you should begin a new waiting loop. This is because you cannot assume the first value you see is what the user intends.
The user may be about to press other switches as well.
Wait for maybe 1/10 second. Exit the loop.
Then see which switches are pressed. Take that as the input value.
Experiment with shorter or longer delay loops, til you get a delay time that works best.
