Globe Led Product Re-engineering.
Prashantakerkar
Member level 4
Attached image for the Globe Led product operated on 230V AC mains supply.
1 Is it possible to modify the product working on alternate source of electrical power viz Batteries?
2 Is it possible to modify the product with the Globe revolving with different speeds achieved with a remote control device?
Thanks & Regards,
Prashant S Akerkar
Yes, and yes.
But not economically.
If you can open the globe it might be possible to fit a low voltage lamp or LED. For the rotation, it depends how it is done at the moment, you might have to find a low voltage motor and gearbox and you need a remote control receiver and some kind of power control to set the speed. The cost would be far higher than the product itself.
