global variable accessing problem
arecssor
Junior Member level 1
hi,
i tried to use interrupts in at8535 to perform a switch operation , am getting an error
my code
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
#include <mega8535.h>
#include <alcd.h>
#include <delay.h>
// External Interrupt 0 service routine
interrupt [EXT_INT0] void ext_int0_isr(void)
x=1; // when int0 pressed x =1
interrupt [EXT_INT1] void ext_int1_isr(void)
x=2;
int x;// global variable declaration
void main(void)
if(x=1)
lcd_putsf('int0');
else if(x==2)
lcd_putsf('int1');
this is the format of the code am getting an error that ISR can't recognize the variable 'x', it shows undefined variable . i used code vision avr how can i resolve this issue
i declared the variable 'x' before void main function, even after that am getting the same error, you can see that a variable 'x' is declared before the void main function .
#include <alcd.h>
#include <delay.h>
x=2;
void main(void)
if(x==1)
lcd_putsf('int0');
else if(x==2)
lcd_putsf('int1');
please provide the code with proper variable declaration , so that i can understand the cause for the error , am using code vision avr for programming .
Thank you
Variable x is used in ISR so declare x before ISR. Make declarations in the first few lines of the code.
tried but no result , same response undefined variable
