AlexisC
Newbie level 3
Glitchs on coutner (Quartus Ii and modelsim)
Hi every body
I facing a problem with quartus II and modelsim.
Here is my VHDL code :
here is my test bench vhdl code :
and here are the results on modelsim:
As you can see there is some kind of glitchs when the adc_tcyc_cnt goes from 0 to 19.
If I change
by :
there is no glitches.
I would apreciate any help.
Thanks
Hi every body
library ieee ;
use ieee.std_logic_1164.all;
use IEEE.numeric_std.all;
--use ieee.std_logic_unsigned.all;
use work.all;
entity AD7960_Ctrl is
port(
m_clk_i: in std_logic; --100MHz clock for timing
reset_n_i: in std_logic; --reset signal active low
clk_o: out std_logic --clock out
end AD7960_Ctrl;
architecture behavioral of AD7960_Ctrl is
constant ADC_CYC_CNT : std_logic_vector(4 downto 0) := "10011" ;
signal adc_tcyc_cnt: std_logic_vector(4 downto 0);
begin
clk_o<= '1' when adc_tcyc_cnt = "00010" else '0' ;
process (m_clk_i,reset_n_i,adc_tcyc_cnt)
begin
if (reset_n_i = '0') then
adc_tcyc_cnt <= ADC_CYC_CNT;
elsif (m_clk_i='1' and m_clk_i'Event)then
if adc_tcyc_cnt /= "00000" then
adc_tcyc_cnt <= std_logic_vector(unsigned(adc_tcyc_cnt) - 1) ;
else
end if ;
end if ;
end process;
end behavioral;
-- testbench for counter_3bit
-- Load Altera libraries for this chip
LIBRARY IEEE;
LIBRARY MAXII;
USE IEEE.STD_LOGIC_1164.ALL;
USE MAXII.MAXII_COMPONENTS.ALL;
entity ad7960_ctrl_tb is
end ad7960_ctrl_tb;
architecture testbench1 of ad7960_ctrl_tb is
-- Set up the signals on the 3bit_counter
signal m_clk_i: std_logic := '0'; --100MHz clock for timing
signal reset_n_i: std_logic:= '0'; --reset signal active low
signal clk_o: std_logic:= '0'; --clock out
constant clk_period_100 : time := 10ns;
begin
-- dut = device under test (same name as top project from Quartus)
dut : entity work.ad7960_ctrl
-- Map the ports from the dut to this testbench
port map (
m_clk_i=> m_clk_i ,
reset_n_i=> reset_n_i ,
clk_o=> clk_o
MAIN_CLK_process :process
begin
m_clk_i<= not m_clk_i; wait for clk_period_100/2;
end process;
stim_proc: process
begin
wait for 13ns;
reset_n_i <='1';
wait;
end process;
end ;
If I change
constant ADC_CYC_CNT : std_logic_vector(4 downto 0) := "10100" ;
Thanks
