[SOLVED] Getting Syntax error(in db statement) in keil ..
tushki7
Full Member level 4
india
Hey Guys,
I am getting syntax error whenever i use DB command to create a table in keil. .
for example take this program:-
;Program for Nokia 3310 LCD PCD8544 48x84 pixcel
		 	SCK		BIT	P1.7
		 	SDIN		BIT	P1.6
		 	D_C		BIT	P1.5
		 	SCE		BIT	P1.4
		 	RES		BIT	P1.3
		 	ORG 0000H
			AJMP MAIN
			ORG 0030H
	MAIN:
			MOV SP,#60H
			MOV P1,#00H
			CLR C
			CALL RESET
			CALL LCD_INIT
		HERE:
			CALL CLEAR_RAM
			MOV DPTR,#MESSAGE
			CALL LCD_STRING
			CALL DELAYS
			CALL CLEAR_RAM
			MOV DPTR,#IMAGE
			CALL DISPLAY
			CALL DELAYS
  		   	AJMP HERE
		DELAYS:	       	 ;1s DELAY
			MOV R5,#10
		D1:
			CALL DELAY
			DJNZ R5,D1
			RET
		DELAY:            	;100ms DELAY
			SETB PSW.4
			MOV R7,#200
		HDH:
			MOV R6,#100
		HD:	NOP
			NOP
			NOP
			DJNZ R6,HD
			DJNZ R7,HDH
			CLR PSW.4
			RET
		RESET:          	 ; RESET
			SETB SCE
			SETB RES
			CLR  RES
			CALL DELAY
			SETB RES
			RET
		LCD_INIT:             			;INITALIZE LCD
			MOV DPTR,#LCDCODE1
			CALL LCD_IN
		   	CALL CLEAR_RAM
		   	MOV R1,#00H   	;Y
		   	MOV R2,#00H    	;X
			CALL CURSOR
			RET
	LCD_IN:
			MOV A,#00H
			MOV R6,#00H
	LOOP3:
			INC R6
			MOVC A,@A+DPTR
			CJNE A,#2FH,NEXT3
			RET
	NEXT3:
			CALL LCD_COM
			MOV A,R6
			AJMP LOOP3
		DISPLAY:            			 ;DISPLAY IMAGE
				MOV R7,#06H
			DO:	PUSH DPL
				PUSH DPH
				MOV R6,#84
			BACK:
				MOV A,#00H
				MOVC A,@A+DPTR
				CALL ROTATE
				CALL LCD_DATA
				CALL IN_DP
				DJNZ R6,BACK
				POP DPH
				POP DPL
				INC DPTR
            				DJNZ R7,DO
				RET
			IN_DP:
				MOV R5,#06H
	  		GO1:	INC DPTR
				DJNZ R5,GO1
				RET
			ROTATE:
				CLR C
				MOV R3,#8H
			ROT:
				RLC A
				MOV 53H,A
				PUSH 53H
				MOV A,R1
				RRC A
				MOV R1,A
				POP 53H
				MOV A,53H
				DJNZ R3,ROT
				MOV A,R1
            				RET
			LCD_COM:            		 ;ROUTINE TO SEND LCD COMMAND
				CLR D_C
				CLR SCE
				NOP
				CALL CLOCK_DATA
				SETB SCE
				NOP
				RET
			LCD_DATA:      		;ROUTINE TO SEND LCD DATA
				SETB D_C
				CLR SCE
				NOP
				CALL CLOCK_DATA
				NOP
				SETB SCE
				RET
			CLOCK_DATA:         		 ;ROUTINE FOR SPI
			 	CLR C
				MOV R5,#08
			HERE1:
				CLR SCK
				RLC A
				MOV SDIN,C
				SETB SCK
				DJNZ R5,HERE1
				RET
			CURSOR:           		 ;SET DISPLAY CURSOR
				MOV A,R1   	  ;Y POINTER
				ANL A,#07H
				ORL A,#40H
				CALL LCD_COM
				MOV A,R2     	 ;X POINTER
				ANL A,#7FH
				ORL A,#80H
				CALL LCD_COM
				RET
		CLEAR_RAM: 			  ;CLEAR RAM
				MOV R1,#00H
				MOV R2,#00H
				CALL CURSOR
				CLR C
				MOV R6,#06
			LOOP:
			   	MOV R7,#84
			LOOP1:
				MOV A,#00H
				CALL LCD_DATA
				DJNZ R7,LOOP1
			   	DJNZ R6,LOOP
			  	 RET
		LCD_STRING:       			  ;ROUTINE TO DISPLAY MESSAGE
				MOV A,#0H
				MOV 50H,#0H
			NEXT:
				INC 50H
				MOVC A,@A+DPTR
				CJNE A,#2FH,NEXT1
				RET
			NEXT1:
				CALL TABLE_PTR
				MOV A,#00H
				CALL LCD_DATA
				MOV A,50H
				AJMP NEXT
			TABLE_PTR:
				PUSH DPL
				PUSH DPH
				MOV DPTR,#TABLE
				MOV B,#05H
				MUL AB
				SUBB A,#0A0H
				JNC HERE2
				DEC B
			HERE2:
			  	MOV R4,A
			  	CJNE R4,#00H,L1
			  	AJMP L3
			  L1:	INC DPTR
				DJNZ R4,L1
			  L3:
				CLR C
				MOV R4,B
			      	CJNE R4,#00H,L2
			      	AJMP L4
				L2:INC DPH
				DJNZ R4,L2
			L4:
				MOV R6,#00H
				MOV A,#00H
			NEXT2:
				INC R6
				MOVC A,@A+DPTR
				CALL LCD_DATA
				MOV A,R6
				CJNE R6,#05H,NEXT2
				POP DPH
				POP DPL
				RET
			LCDCODE1:
				DB 21H
			  	DB 90H
				DB 07H
				DB 13H
				DB 20H
				DB 09H
				DB 08H
			   	DB 0CH
         				DB 2FH
MESSAGE: DB "  GOOD DAY !/"
TABLE:        ;HEX ARRAY TO DISPLAY CHARACTERS
DB		000H,000H,000H,000H,000H,	; 20 space
DB		000H,000H,05fH,000H,000H,	; 21 !
DB		000H,007H,000H,007H,000H,	; 22 "
DB		014H,07fH,014H,07fH,014H,	; 23 #
DB		024H,02aH,07fH,02aH,012H,	; 24 $
DB		023H,013H,008H,064H,062H,	; 25 %
DB		036H,049H,055H,022H,050H,	; 26 &
DB		000H,005H,003H,000H,000H,	; 27 '
DB		000H,01cH,022H,041H,000H,	; 28 (
DB		000H,041H,022H,01cH,000H,	; 29 )
DB		014H,008H,03eH,008H,014H,	; 2a *
DB		008H,008H,03eH,008H,008H,	; 2b +
DB		000H,050H,030H,000H,000H,	; 2c ,
DB		008H,008H,008H,008H,008H,	; 2d -
DB		000H,060H,060H,000H,000H,	; 2e .
DB		020H,010H,008H,004H,002H,	; 2f /
DB		03eH,051H,049H,045H,03eH,	; 30 0
DB		000H,042H,07fH,040H,000H,	; 31 1
DB		042H,061H,051H,049H,046H,	; 32 2
DB		021H,041H,045H,04bH,031H,	; 33 3
DB		018H,014H,012H,07fH,010H,	; 34 4
DB		027H,045H,045H,045H,039H,	; 35 5
DB		03cH,04aH,049H,049H,030H,	; 36 6
DB		001H,071H,009H,005H,003H,	; 37 7
DB		036H,049H,049H,049H,036H,	; 38 8
DB		006H,049H,049H,029H,01eH,	; 39 9
DB		000H,036H,036H,000H,000H,	; 3a :
DB		000H,056H,036H,000H,000H,	; 3b ;
DB		008H,014H,022H,041H,000H,	; 3c <
DB		014H,014H,014H,014H,014H,	; 3d =
DB		000H,041H,022H,014H,008H,	; 3e >
DB		002H,001H,051H,009H,006H,	; 3f ?
DB		032H,049H,079H,041H,03eH,	; 40 @
DB		07eH,011H,011H,011H,07eH,	; 41 A
DB		07fH,049H,049H,049H,036H,	; 42 B
DB		03eH,041H,041H,041H,022H,	; 43 C
DB		07fH,041H,041H,022H,01cH,	; 44 D
DB		07fH,049H,049H,049H,041H,	; 45 E
DB		07fH,009H,009H,009H,001H,	; 46 F
DB		03eH,041H,049H,049H,07aH,	; 47 G
DB		07fH,008H,008H,008H,07fH,	; 48 H
DB		000H,041H,07fH,041H,000H,	; 49 I
DB		020H,040H,041H,03fH,001H,	; 4a J
DB		07fH,008H,014H,022H,041H,	; 4b K
DB		07fH,040H,040H,040H,040H,	; 4c L
DB		07fH,002H,00cH,002H,07fH,	; 4d M
DB		07fH,004H,008H,010H,07fH,	; 4e N
DB		03eH,041H,041H,041H,03eH,	; 4f O
DB		07fH,009H,009H,009H,006H,	; 50 P
DB		03eH,041H,051H,021H,05eH,	; 51 Q
DB		07fH,009H,019H,029H,046H,	; 52 R
DB		046H,049H,049H,049H,031H,	; 53 S
DB		001H,001H,07fH,001H,001H,	; 54 T
DB		03fH,040H,040H,040H,03fH,	; 55 U
DB		01fH,020H,040H,020H,01fH,	; 56 V
DB		03fH,040H,038H,040H,03fH,	; 57 W
DB		063H,014H,008H,014H,063H,	; 58 X
DB		007H,008H,070H,008H,007H,	; 59 Y
DB		061H,051H,049H,045H,043H,	; 5a Z
DB		000H,07fH,041H,041H,000H,	; 5b [
DB		002H,004H,008H,010H,020H,	; 5c Yen Currency Sign
DB		000H,041H,041H,07fH,000H,	; 5d ]
DB		004H,002H,001H,002H,004H,	; 5e ^
DB		040H,040H,040H,040H,040H,	; 5f _
DB		000H,001H,002H,004H,000H,	; 60 `
DB		020H,054H,054H,054H,078H,	; 61 a
DB		07fH,048H,044H,044H,038H,	; 62 b
DB		038H,044H,044H,044H,020H,	; 63 c
DB		038H,044H,044H,048H,07fH,	; 64 d
DB		038H,054H,054H,054H,018H,	; 65 e
DB		008H,07eH,009H,001H,002H,	; 66 f
DB		00cH,052H,052H,052H,03eH,	; 67 g
DB		07fH,008H,004H,004H,078H,	; 68 h
DB		000H,044H,07dH,040H,000H,	; 69 i
DB		020H,040H,044H,03dH,000H,	; 6a j
DB		07fH,010H,028H,044H,000H,	; 6b k
DB		000H,041H,07fH,040H,000H,	; 6c l
DB		07cH,004H,018H,004H,078H,	; 6d m
DB		07cH,008H,004H,004H,078H,	; 6e n
DB		038H,044H,044H,044H,038H,	; 6f o
DB		07cH,014H,014H,014H,008H,	; 70 p
DB		008H,014H,014H,018H,07cH,	; 71 q
DB		07cH,008H,004H,004H,008H,	; 72 r
DB		048H,054H,054H,054H,020H,	; 73 s
DB		004H,03fH,044H,040H,020H,	; 74 t
DB		03cH,040H,040H,020H,07cH,	; 75 u
DB		01cH,020H,040H,020H,01cH,	; 76 v
DB		03cH,040H,030H,040H,03cH,	; 77 w
DB		044H,028H,010H,028H,044H,	; 78 x
DB		00cH,050H,050H,050H,03cH,	; 79 y
DB		044H,064H,054H,04cH,044H,	; 7a z
DB		000H,008H,036H,041H,000H,	; 7b <
DB		000H,000H,07fH,000H,000H,	; 7c |
DB		000H,041H,036H,008H,000H,	; 7d >
DB		010H,008H,008H,010H,008H,	; 7e Right Arrow 	->
DB		078H,046H,041H,046H,078H	; 7f Left Arrow	<-
IMAGE:       ;HEX ARRAY FOR IMAGE
DB 000H,000H,0fdH,000H,000H,080H,
DB 000H,007H,0ffH,000H,001H,000H,
DB 000H,00fH,0ffH,086H,002H,000H,
DB 000H,01fH,0ffH,0f9H,004H,000H,
DB 000H,03fH,0ffH,0fcH,084H,000H,
DB 000H,03fH,0ffH,0fcH,0c4H,000H,
DB 000H,07fH,0ffH,0feH,03cH,001H,
DB 000H,07fH,0ffH,0feH,014H,002H,
DB 000H,07fH,0ffH,0feH,00bH,006H,
DB 000H,07fH,0ffH,0ffH,008H,01aH,
DB 000H,07fH,0ffH,0feH,00cH,002H,
DB 000H,07fH,0ffH,0ffH,006H,004H,
DB 000H,07fH,0ffH,0feH,003H,0f8H,
DB 000H,03fH,0ffH,0feH,003H,0fcH,
DB 000H,03fH,0ffH,0fcH,003H,0f8H,
DB 000H,01fH,0ffH,0fcH,001H,0fcH,
DB 000H,00fH,0ffH,0f8H,001H,0fcH,
DB 000H,007H,0ffH,0f0H,001H,0fcH,
DB 000H,001H,0ffH,0e0H,001H,0fcH,
DB 0e0H,000H,0ffH,0fcH,001H,0fcH,
DB 0f0H,003H,0ffH,0efH,001H,0fcH,
DB 0f8H,007H,0ffH,081H,0c1H,0fcH,
DB 0fcH,00fH,0feH,000H,061H,0fcH,
DB 0feH,03fH,0fcH,000H,030H,0fcH,
DB 0feH,03fH,0fcH,000H,018H,0fcH,
DB 0ffH,07fH,0f8H,000H,00cH,0fcH,
DB 0ffH,0ffH,0f8H,000H,006H,0fcH,
DB 0ffH,0ffH,0f8H,000H,002H,0feH,
DB 0ffH,0ffH,0f8H,000H,003H,0feH,
DB 0ffH,0ffH,0f8H,000H,001H,0feH,
DB 0ffH,0ffH,0f8H,020H,007H,0feH,
DB 0ffH,0ffH,0f8H,020H,001H,0feH,
DB 0ffH,0ffH,0fcH,03cH,008H,07eH,
DB 0ffH,0ffH,0fcH,027H,0ffH,03eH,
DB 0ffH,0ffH,0feH,011H,0ffH,09eH,
DB 0ffH,0c0H,00fH,000H,07fH,0cfH,
DB 0ffH,080H,001H,080H,03fH,0efH,
DB 0ffH,000H,000H,080H,00fH,0cfH,
DB 0f6H,000H,000H,000H,00fH,0dfH,
DB 0c2H,000H,000H,000H,007H,09fH,
DB 002H,060H,000H,000H,003H,0bfH,
DB 003H,040H,0bfH,000H,001H,03fH,
DB 001H,081H,003H,0c0H,001H,07fH,
DB 001H,082H,007H,0e0H,001H,0ffH,
DB 001H,0c0H,003H,0e0H,000H,0ffH,
DB 000H,0f1H,080H,0c0H,000H,0ffH,
DB 000H,078H,03fH,000H,000H,0ffH,
DB 000H,07eH,000H,004H,000H,0ffH,
DB 000H,030H,000H,008H,000H,0feH,
DB 000H,018H,0dfH,0b0H,000H,0feH,
DB 000H,00cH,087H,0e0H,000H,0feH,
DB 000H,003H,023H,0e0H,001H,0feH,
DB 000H,000H,0faH,0c0H,001H,0feH,
DB 000H,000H,01fH,0c0H,003H,0feH,
DB 000H,000H,000H,040H,003H,0feH,
DB 000H,000H,007H,0f0H,007H,0feH,
DB 000H,000H,01eH,0f8H,00dH,0feH,
DB 000H,000H,018H,038H,01bH,0faH,
DB 000H,000H,019H,0f8H,063H,0f1H,
DB 000H,000H,01fH,0ffH,0c3H,0f0H,
DB 000H,000H,00fH,0e0H,003H,0f0H,
DB 000H,000H,002H,000H,003H,0f0H,
DB 000H,000H,000H,000H,003H,0f0H,
DB 000H,000H,000H,000H,000H,000H,
DB 0feH,000H,07cH,0feH,0feH,0c0H,
DB 070H,000H,082H,010H,092H,020H,
DB 00eH,0feH,082H,020H,092H,01eH,
DB 070H,000H,082H,058H,092H,020H,
DB 0feH,000H,044H,086H,000H,0c0H,
END
I am getting syntax error whenever i use DB command to create a table or some database: here is pic :-
Help me Guys .. 8-O
Hi Tushki7,
Your syntax error is due to the final comma at the end of each DB statement. Each DB statement is terminated by by the absence of a comma, each comma must be followed by a valid byte entry.
Your initial code:
DB		000H,060H,060H,000H,000H[COLOR="#FF0000"],[/COLOR]	; 2e .
DB		020H,010H,008H,004H,002H[COLOR="#FF0000"],[/COLOR]	; 2f /
DB		03eH,051H,049H,045H,03eH[COLOR="#FF0000"],[/COLOR]	; 30 0
DB		000H,042H,07fH,040H,000H[COLOR="#FF0000"],[/COLOR]	; 31 1
DB		042H,061H,051H,049H,046H[COLOR="#FF0000"],[/COLOR]	; 32 2
DB		021H,041H,045H,04bH,031H[COLOR="#FF0000"],[/COLOR]	; 33 3
DB		018H,014H,012H,07fH,010H[COLOR="#FF0000"],[/COLOR]	; 34 4
Lagging commas removed:
TABLE:		        DB		000H,000H,000H,000H,000H	; 20 space
			DB		000H,000H,05fH,000H,000H	; 21 !
			DB		000H,007H,000H,007H,000H	; 22 "
			DB		014H,07fH,014H,07fH,014H	; 23 #
			DB		024H,02aH,07fH,02aH,012H	; 24 $
			DB		023H,013H,008H,064H,062H	; 25 %
			DB		036H,049H,055H,022H,050H	; 26 &
			DB		000H,005H,003H,000H,000H	; 27 '
			DB		000H,01cH,022H,041H,000H	; 28 (
			DB		000H,041H,022H,01cH,000H	; 29 )
			DB		014H,008H,03eH,008H,014H	; 2a *
			DB		008H,008H,03eH,008H,008H	; 2b +
			DB		000H,050H,030H,000H,000H	; 2c ,
			DB		008H,008H,008H,008H,008H	; 2d -
			DB		000H,060H,060H,000H,000H	; 2e .
			DB		020H,010H,008H,004H,002H	; 2f /
			DB		03eH,051H,049H,045H,03eH	; 30 0
			DB		000H,042H,07fH,040H,000H	; 31 1
			DB		042H,061H,051H,049H,046H	; 32 2
			DB		021H,041H,045H,04bH,031H	; 33 3
			DB		018H,014H,012H,07fH,010H	; 34 4
			DB		027H,045H,045H,045H,039H	; 35 5
			DB		03cH,04aH,049H,049H,030H	; 36 6
			DB		001H,071H,009H,005H,003H	; 37 7
			DB		036H,049H,049H,049H,036H	; 38 8
			DB		006H,049H,049H,029H,01eH	; 39 9
			DB		000H,036H,036H,000H,000H	; 3a :
			DB		000H,056H,036H,000H,000H	; 3b ;
			DB		008H,014H,022H,041H,000H	; 3c <
			DB		014H,014H,014H,014H,014H	; 3d =
			DB		000H,041H,022H,014H,008H	; 3e >
			DB		002H,001H,051H,009H,006H	; 3f ?
			DB		032H,049H,079H,041H,03eH	; 40 @
			DB		07eH,011H,011H,011H,07eH	; 41 A
			DB		07fH,049H,049H,049H,036H	; 42 B
			DB		03eH,041H,041H,041H,022H	; 43 C
			DB		07fH,041H,041H,022H,01cH	; 44 D
			DB		07fH,049H,049H,049H,041H	; 45 E
			DB		07fH,009H,009H,009H,001H	; 46 F
			DB		03eH,041H,049H,049H,07aH	; 47 G
			DB		07fH,008H,008H,008H,07fH	; 48 H
			DB		000H,041H,07fH,041H,000H	; 49 I
			DB		020H,040H,041H,03fH,001H	; 4a J
			DB		07fH,008H,014H,022H,041H	; 4b K
			DB		07fH,040H,040H,040H,040H	; 4c L
			DB		07fH,002H,00cH,002H,07fH	; 4d M
			DB		07fH,004H,008H,010H,07fH	; 4e N
			DB		03eH,041H,041H,041H,03eH	; 4f O
			DB		07fH,009H,009H,009H,006H	; 50 P
			DB		03eH,041H,051H,021H,05eH	; 51 Q
			DB		07fH,009H,019H,029H,046H	; 52 R
			DB		046H,049H,049H,049H,031H	; 53 S
			DB		001H,001H,07fH,001H,001H	; 54 T
			DB		03fH,040H,040H,040H,03fH	; 55 U
			DB		01fH,020H,040H,020H,01fH	; 56 V
			DB		03fH,040H,038H,040H,03fH	; 57 W
			DB		063H,014H,008H,014H,063H	; 58 X
			DB		007H,008H,070H,008H,007H	; 59 Y
			DB		061H,051H,049H,045H,043H	; 5a Z
			DB		000H,07fH,041H,041H,000H	; 5b [
			DB		002H,004H,008H,010H,020H	; 5c Yen Currency Sign
			DB		000H,041H,041H,07fH,000H	; 5d ]
			DB		004H,002H,001H,002H,004H	; 5e ^
			DB		040H,040H,040H,040H,040H	; 5f _
			DB		000H,001H,002H,004H,000H	; 60 `
			DB		020H,054H,054H,054H,078H	; 61 a
			DB		07fH,048H,044H,044H,038H	; 62 b
			DB		038H,044H,044H,044H,020H	; 63 c
			DB		038H,044H,044H,048H,07fH	; 64 d
			DB		038H,054H,054H,054H,018H	; 65 e
			DB		008H,07eH,009H,001H,002H	; 66 f
			DB		00cH,052H,052H,052H,03eH	; 67 g
			DB		07fH,008H,004H,004H,078H	; 68 h
			DB		000H,044H,07dH,040H,000H	; 69 i
			DB		020H,040H,044H,03dH,000H	; 6a j
			DB		07fH,010H,028H,044H,000H	; 6b k
			DB		000H,041H,07fH,040H,000H	; 6c l
			DB		07cH,004H,018H,004H,078H	; 6d m
			DB		07cH,008H,004H,004H,078H	; 6e n
			DB		038H,044H,044H,044H,038H	; 6f o
			DB		07cH,014H,014H,014H,008H	; 70 p
			DB		008H,014H,014H,018H,07cH	; 71 q
			DB		07cH,008H,004H,004H,008H	; 72 r
			DB		048H,054H,054H,054H,020H	; 73 s
			DB		004H,03fH,044H,040H,020H	; 74 t
			DB		03cH,040H,040H,020H,07cH	; 75 u
			DB		01cH,020H,040H,020H,01cH	; 76 v
			DB		03cH,040H,030H,040H,03cH	; 77 w
			DB		044H,028H,010H,028H,044H	; 78 x
			DB		00cH,050H,050H,050H,03cH	; 79 y
			DB		044H,064H,054H,04cH,044H	; 7a z
			DB		000H,008H,036H,041H,000H	; 7b <
			DB		000H,000H,07fH,000H,000H	; 7c |
			DB		000H,041H,036H,008H,000H	; 7d >
			DB		010H,008H,008H,010H,008H	; 7e Right Arrow 	->
IMAGE:		DB 000H,000H,0fdH,000H,000H,080H
Replace both your Data Byte tables with the above correction and your code should assemble fine.
BigDog
Reactions: tushki7
    tushki7
Hi Biddogguru,
Actually i already tried this, but i thought removing last comma will terminate the DB derivative and force it to go to the main program i.e after executing first DB instruction it will terminate and does not execute 2nd db instruction ..
so its ok to remove last comma's--> hmm in other programs which i had downloaded from (different sites), programs are exactly same i.e all db statements are ended with those commas(as in this program). .
moreover why should uploader will post wrong programs--> means that those programs are fine and they are debugging well with those comma's ..
there is something i am missing!!!
Here's the reference to the DB Assembler Directive:
You maybe able start a Data Byte table with the directive "DB" and terminate the first line with a comma then continue the next line without the directive "DB" to start the current line.
However, I have not tried this technique.
BigDog
Reactions: tushki7
    tushki7
