Darktrax
Full Member level 5
The scenario is quality microwave kit put in series, typically some waveguide, polarizer, low noise amplifier, down-converter.
Typically, a reasonable specification for a down-converter is (say) +/- 0.25dB for any 40MHz segment, and +/- 1dB over the band, which might be 400MHz (at X-Band). This is probably a worst case. The delivered kit might be better than that. Sometimes the partial band spec is over 30Mhz, sometimes 50MHz.
A reasonable specification for a LNA is (say) +/- 1dB over the band.
Waveguide switching and other extras might have their own ripples.
The way I see it, the passband characteristic will be the sum of the characteristics of the various parts taken together. One might get lucky so that a "bump" or tilt in the response of one might counter some "dip" in another, to give a great overall result, or one can get unlucky, where two "droops" coincide.
Where the modulation is various forms of phase-shifted keying, like 8PSK or DQPSK, it is hard to see small variations in passband response can matter much. Gross variations are obviously not acceptable.
Even if the modulation types involve QAM or any other type of amplitude modulation, the changes are so swift that it has components that spread throughout the modulated spectrum. One cannot really say that a "bump" at some frequency affected a specific data waveform amplitude in the time domain, because it took energy from the entire spectrum.
Hence I ask.
. What is the best that can be expected for passband ripple/tilt using high quality kit?
. Are there any techniques to counter passband ripple? What is the best stuff around?
. An equalizing filter to counter "tilt" sounds feasible, but is it needed/justified? I don't know how I would get hold of such kit.
. Is a specification of +/- 0.5dB, or even +/- 0.75 dB (guaranteed) a common, reasonable, achievable thing? Adding up the specs of the parts would indicate it is not!
Hence I ask.
