kvn0smnsn
Junior Member level 1
I've got four different modules that I'm using in an attempt to divide a six-bit value by ten, and then calculate a quotient and a remainder.
If I put them all in one file, it works just fine.
But if I put them in four different files like so:
Mux.v:
and FullAdder.v:
and AddVector.v:
and then finally DivByTen.v:
and then I bring "DivByTen.v" into EDA Playground and click on <Run>, I get
message:
Note that if I execute the following command I get these results:
So all the files are actually there. Why is EDA Playground telling me 'No such file or directory'?
Mux.v:
module Mux #( nmBits = 1)
( result, control, hgVal, lwVal);
output [ nmBits-1:0] result;
input control;
input [ nmBits-1:0] hgVal;
input [ nmBits-1:0] lwVal;
genvar bt;
generate
for (bt = 0; bt < nmBits; bt = bt + 1)
begin
assign result[ bt] = control ? hgVal[ bt] : lwVal[ bt];
end
endgenerate
endmodule
and FullAdder.v:
module FullAdder( cOut, sum, aOp, bOp, cIn);
output cOut;
output sum;
input aOp;
input bOp;
input cIn;
assign cOut = aOp & bOp | aOp & cIn | bOp & cIn;
assign sum = aOp ^ bOp ^ cIn;
endmodule
and AddVector.v:
`include "C:\\Users\\Kevin\\Uvu\\3740\\Ds\\Final\\Params\\Inc\\FullAdder.v"
module AddVector #( nmBits = 1)
( sum, aOp, bOp);
output [ nmBits :0] sum;
input [ nmBits-1:0] aOp;
input [ nmBits-1:0] bOp;
wire [ nmBits :0] carry;
assign carry[ 0] = 1'b0;
assign sum[ nmBits] = carry[ nmBits];
genvar bt;
generate
begin
FullAdder fa( carry[ bt + 1], sum[ bt], aOp[ bt], bOp[ bt], carry[ bt]);
end
endgenerate
endmodule
`include "C:\\Users\\Kevin\\Uvu\\3740\\Ds\\Final\\Params\\Inc\\AddVector.v"
`include "C:\\Users\\Kevin\\Uvu\\3740\\Ds\\Final\\Params\\Inc\\Mux.v"
module DivByTen( quotient, remainder, dividend);
output [ 2:0] quotient;
output [ 3:0] remainder;
input [ 5:0] dividend;
wire [ 6:0] sum40;
wire [ 6:0] sum20;
wire [ 5:0] sum10;
wire [ 5:0] result40;
wire [ 4:0] result20;
wire [ 3:0] result10;
AddVector av40 #(6)( sum40, dividend, 6'b011000); // Subtract 40.
AddVector av20 #(6)( sum20, result40, 6'b101100); // Subtract 20.
AddVector av10 #(5)( sum10, result20, 5'b10110 ); // Subtract 10.
// For each mux, pass through the least significant bits of the sum if the
// most significant bit is high, which indicates the subtraction is positive;
// otherwise pass through the value before the subtraction.
Mux mx40 #(6)( result40, sum40[ 6], sum40[ 5:0], dividend);
Mux mx20 #(5)( result20, sum20[ 6], sum20[ 4:0], result40[ 4:0]);
Mux mx10 #(4)( result10, sum10[ 5], sum10[ 3:0], result20[ 3:0]);
assign quotient[ 2] = sum40[ 6];
assign quotient[ 1] = sum20[ 6];
assign quotient[ 0] = sum10[ 5];
assign remainder = result10;
endmodule
message:
Parsing design file 'design.sv'
Error-[SFCOR] Source file cannot be opened
Source file "C:\Users\Kevin\Uvu\3740\Ds\Final\Params\Inc\AddVector.v" cannot
be opened for reading due to 'No such file or directory'.
Please fix above issue and compile again.
"design.sv", 1
Source info: `include
1 error
CPU time: .140 seconds to compile
Exit code expected: 0, received: 1
Done
C:\Users\Kevin\Uvu\3740>dir C:\Users\Kevin\Uvu\3740\Ds\Final\Params\Inc
Volume in drive C has no label.
Volume Serial Number is 843B-37F1
Directory of C:\Users\Kevin\Uvu\3740\Ds\Final\Params\Inc
11/21/2022 08:50 AM <DIR> .
11/21/2022 08:50 AM <DIR> ..
11/21/2022 08:55 AM 540 AddVector.v
11/21/2022 08:56 AM 1,233 DivByTen.v
11/10/2022 08:50 PM 221 FullAdder.v
11/17/2022 09:08 PM 383 Mux.v
11/21/2022 09:03 AM 4,330 NoSuchFile.Txt
11/21/2022 08:42 AM 1,094 t_DivByTen.v
6 File(s) 7,801 bytes
2 Dir(s) 140,274,835,456 bytes free
