My problem is that I am sending an analog signal into the AVR and converting it into Digital and than sending it through the serial port by using Tx/Rx of AVR.
I want to get this data into MATLAB simulink with the help of Instrument control tool box.
My Question is how this serial data will again be combined in order to show the original waveform on the graph?
Like if I am giving a sinusoidal input to AVR than how to reconstruct that sinusoid in the MATLAB? and Will this data acquired will be in real time or not?
My second question is I want to have the frequencies of 1Hz to 20Hz which filter shall I be using in simulink than Analog or Discrete filter.
s = serial('COM1','BaudRate',9600,'TimeOut',3);
fopen(handles.s);
[rec count msg] = fgets(s); %instead of this line you can use [B][I]rec = fgets(s)[/I][/B] to receive data from serial port
%To send Data
fprintf(handles.s,'%s','Your Name or anything u want');
And then you can use this to plot anything in MATLAB
Hope this help
You can acquire data and Plot it in real time using MATLAB..
Few Days Back i had made a project which acquire data from 60 Sensors and Plot the Temperature Vs Time in real time...
But the Problem is that My system is not so much fast.. That's why my system hangs many times...
But there is no loss in data...
