D@rkD@iver
Newbie level 1
- Joined
- Apr 22, 2012
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,290
Hi, I'm trying to read ROM code from DS18B20 using AtTiny2313.
DS18B20 gives presense signal as it supposed to. Then I sent 0x33 command and read 8 bytes.
I read 8 non-0xFF bytes. but they are not representing the ROM code (LS byte isn't 0x28).
I tested it in proteus and in real device. the result is similar - just 8 numbers (diffrent for device and proteus). But those numbers repeat after I restart the system.
DS_Send_Byte function should be right, DS18B20 recognizes it. I think so because I read exactly 8 numbers(ninth byte is 0xFF) and if I change 0x33 to other command it receives all 0xFFs.
I'm concerned with DS_Read_Byte function.
this is what I get in proteus
LCD is fine I double checked it.
By the way the code of DS18B20 in proteus is B8C530
So what might be the problem?
Thank you.
if (DS_isPresent())
LCD_Clear_Display();
DS_Send_Byte(0x33);
for (int i=0; i<8; i++)
byte b = DS_Read_Byte();
LCD_Show_Byte(b);
return 0;
byte DS_Read_Bit()
byte r = 0;
DSDDR |= 1<<DSBIT;
DSPORT &= ~(1<<DSBIT);
_delay_us(15);
DSDDR &= ~(1<<DSBIT);
_delay_us(15);
if (DSPIN&(1<<DSBIT))
r = 1;
_delay_us(30);
return r;
byte DS_Read_Byte()
byte b = 0;
b = b << 1;
b = b + DS_Read_Bit();
return b;
Thank you.
