I think you got that backwards.Derill03 said:The high-low transition is needed on the RST pin
Also, I think you shouldn't tie /RESET to GND hard, as it is a bidirectional pin (it attempts to output high when the internal reset is active). You might want to leave /RESET pin floating (or pulled low weakly) and look at that output level; as well as look at whether and how the oscillator starts at powerup, together with looking at the VCC/GND directly at the mcu's power pins, for irregularities during powerup.The user should note that this part is tested and guaranteed to operate down to 4.5V (10%) and that VRST (min) is specified below that point. This indicates that there is a range of voltages [VMIN to V RST(min)] where the processor's operation is not guaranteed, but the reset trip point has not been reached. This should not be an issue in most applications, but should be considered when proper operation must be maintained at all times. For these applications, it may be desirable to use a more accurate external reset.
