Generating two Square wave 180 degrees out of phase
vinay13
Newbie level 5
Newbie level 5
i want to generate two square waves 180 degrees out of phase of 300KHZ using PWM of pic 18F4620...and the compiler i m using is MIkroC.
i have successfully generated a single square wave at one PWM channel. i need help to generate another square wave of same frequency but 180 degrees out of phase..!!
THERE IS AN IC 4048 WHICH GENERATES TWO OUT OF PHASE SQUARES.
YOU CAN SIMPLY USE A UNITY GAIN OPAMP INVERTER HERE AT PICS OUTPUT.
SELECT THE RESISTORS (INPUT AND FEEDBACK ) FOR A GAIN OF ONE BY Ri =Rf/10.
i hope this will do it for you.
select an opamp with a bandwidth of 500 Khz.
another idea is usage of a transistor with SL 100 .
another idea is like this,
you define output of pins a,b as the positive and negetive of a value stored in a registor.
now vary this value between its positive and negetive.(by software of course). i hope this algorith will work.
I am not familiar with pic platform.
