[SOLVED] generating two pwm signals simultaneously
minhajzfr1
hi all,
i am using pic 16f877a which has two pwm channels. here is the code i am using pic basic compiler.problem is that if PORTD.4=1 then FIRST PORTD.0 generate pwm signal then PORTD.1 generate pwm signal i want them both at same time. plz help in pic basic beacause i know nothing about assembly or C
Maybe this thread will help.
You can run away from C but sooner or later you'll need to learn it if you're serious about using microcontrollers.
BASIC has little place in programming these days, as much as I like the language. You'll find that very few
people understand the PIC BASIC syntax. Since you're having to learn PIC BASIC anyway, you may as well expend the
effort in a more popular language (C).
thanks it really helped . i am a beginner so i dont know commands for pic initialization like watch dog timer,programming protection e.t.c for pic16f877a. it is reprogrammable device with also low voltage programming that has to be disabled
