Generating PWM using altera software
tobman
hi, i want to generate pwm using altera, i have built a circuit using counters, but am having errors. I have attached the circuit diagram. Would be glad if someone can take a look at it, and see what am doing wrong. Thanks
as a suggest,u could use a rtl model to construct the PWM circuit,it's quite simple
as you use the 74series circuit,in my view,maybe nobody will take a look to check out
the circuit
