Depends on the process you're using. If you are just designing a sample circuit using components from the basic libraries is going to be very complicated to do layout because you will have to define each of the mask layers, DRC and LVS rules yourself. Now, if you are using a specific process like AMI or TSMC and you have a PDK install, the process is quite straight forward. Are you using something like this?? Please try to give as much info as possible; is hard to tell you how to proceed if we don't know what you have available.
Virtuso layout XL is used to generate the layout from schematic, you can then either route it manually. well if you need the steps then follow this link, well you can also google down for the VXL tutorials if you need further information.
When generating layout from schematic in Layout XL I get only pins (no transistors)
What could be a problem?
I use NCSU EDA libraries (NCSU EDA Wiki - NCSU EDA Wiki).
Problem occurs for simple inverter case,
and when I go to Library Manager in Cadence,
and choose layout view for nmos and pmos they exist (i.e. layout editor shows these layouts)
