Generate BIn file from ASM file for 89c2051
pasicr
Advanced Member level 1
Macedonia
laufschr
I need software for generate BIN file from ASM file for 89c2051. I try with ml-asm51 and I receve 50 errors on this file.
The original bin file from www.woe.de.vu work fine.
I need to change something in asm file and generate bin file, but with ml-asm51 not work,
regards
Re: Generate BIn file from ASM file from 89c2051
Define symbols ..
Just add something like $MOD252 and everything should work fine ..
.. see attached files ..
Regards,
IanP
$MOD252
;*                 LAUFSCHR.ASM  V2.2b                    *
;* Laufschrift-Anzeige mit LEDs                           *
;* Mehrere MAX7219 kaskadiert, Module mit jeweils         *
;* 8x8 LEDs; Zeichensatz 5x8                              *
;* Assemblerprogramm fuer 8051-kompatible Controller,     *
;* z.B. AT89C51, Quarzfrequenz 11,0592 MHz                *
;* Das nachfolgende Programm steuert bis zu 11 Module an. *
;* World Of Electronics                                   *
;* [I]**broken link removed**[/I]                                   *
;* [email]woe@topmail.de[/email]                                         *
;* (c) WOE, 1999-2001                                     *
DIN  equ p1.0  ; DIN an Port 1.0
CLCK equ p1.1  ; CLK an Port 1.1
LOAD equ p1.2  ; LOAD an Port 1.2
scl equ p3.5   ; SCL fuer I2C-Bus
sda equ p3.7   ; SDA fuer I2C-Bus
jumper_ser equ  p1.6  ; Jumper fuer seriellen Download
jumper_eep equ  p3.2  ; Jumper fuer EEPROM-Betrieb
jumper_baud equ p3.3  ; Jumper fuer ser. Baudrate
jp_baud_600 equ p1.5  ; Jumper fuer ser. Baudrate 600 Baud
    pasicr
Thanks IanP,
because I do not experience with atmel this is very greath help for me,
regards
