Generate a random number using interrupt
Greital
hi
still working on my 8051 project using assembly language, and now I'm in phase 4 --->>>> the last phase ;)
in this phase we should generate 2 random numbers as following:
1. one digit (1-9)
2. two digit (10-99)
and by using push button we pick randomly the number
we have done one digit perfectly, but we face a problem with the two digit :(
we used a counter with 99 numbers and decrements it each time until the user push a button to interrupt the function and show the number randomly
but the problem that it shows the one digit also :???: :cry:
we tried to make the counter to start from 10 and increment it each time until we reach 99 --->>> but also it didn't work :bang:
we tried and tried and tried :bang: but nothing work
the code :
    ORG 0H
    LJMP MAIN
    ORG 0003H ; EX0 interrupt vector address
    LJMP EX0ISR
    ORG 0030H
MAIN:
    MOV IE,#10000001B ; Enable EX0 interrupts
    SETB IT0 ;Make EX0 edge-triggered interrupt
    LCALL INLCD ; Initialize LCD
LABEL:
    MOV    R4,#99
LOOP:
    DJNZ    R4,LOOP
    SJMP LABEL
EX0ISR:
    MOV    A,R4
    CJNE    R4,#09,GENERATE
COME_HERE:
    DJNZ    R4,COME_HERE
    SJMP    OUT
GENERATE:
    MOV    44H,A
    MOV A,#1000B ; Move cursor to 1st line - send high nibble
    LCALL CMD
    MOV A,#0000B ; send low nibble
    LCALL CMD
    LCALL LDELAY ; 4.1 msec required for this command
    MOV    A,44H
    MOV    B,#10
    DIV    AB
    MOV    36H,B
    ADD A,#30H
    LCALL WCHR
    MOV    A,36H
    ADD    A,#30H
    LCALL WCHR
OUT:
    RETI
please help :(
Mandar Joshi
Member level 2
You successfully did for one digit number...right? Then what happens when you go for two digit number? What do you see on display?
If it shows only single number for two digit logic then problem could be in your display logic.
While displaying two digit number how do you separate higher and lower digit?
Arya Kumar
Member level 4
Write a C code and generate assembly from it.(there will be a command don't know which IDE are u using)
show it to ur teacher and then enjoy ur life.
