Eshal
Advanced Member level 1
- Joined
- Aug 29, 2012
- Messages
- 470
- Helped
- 16
- Reputation
- 32
- Reaction score
- 15
- Trophy points
- 1,298
- Location
- Nowhere :)
- Activity points
- 5,149
Hello to all experts!
I want to generate two different waves on two different port pins of different duty cycle in 8051 using assembly language.
one wave is of 10 KHz of 50% duty cycle on pin p1.0
other wave is of 1 KHz of 10% duty cycle on pin p0.0
Here is the code what I get until now.
What changes should I make in order to satisfy above requirements? The above code shown is generating two different wave of 10KHz and 1KHz but both are 50% duty cycle. I want 10KHz as 50% and 1KHz as 10%.
Thank you very much
Princess
org 0
mov tmod, #12h ;timer1 in mode=1 and timer0 in mode-2
mov th0, #-50 ;reload value for timer0
setb tr0 ;start timer0
loop: mov th1, #0feh
mov tl1, #0ch
setb tr1
wait: jnb tf0, next ;check if timer0 is overflowed
clr tf0 ;clear flag bit of timer0 is overflowed
cpl p1.0
next: jnb tf1, wait ;chekc if timer1 is overflowed
clr tr1 ;stop timer1
clr tf1 ;clear flag bit of timer1 is overflowed
cpl p0.0
sjmp loop
end
Thank you very much
Princess
