GDS file import to HFSS
Bahaa Radi
Newbie level 3
Newbie level 3
Hello
I am trying to import a design from cadence to HFSS for simulation. I figured that I have to define a layer-map file for the design to be imported in 3D and I did that. The problem I have is that dielectrics don't show up in the GDS file nor in HFSS. Do I have to define and draw them manually ?? is there a better way to do it ??
Thanks !
Hello Bahaa,
You will have to manually add the dielectric layers between the metal layers. No other way to do it.
