Could this be the intended waveform? (Found by internet search)
Yes that is what we require and isn't the configuration in the third image more like a half-bridge configuration.
As far as the tailoring is concerned, I have tried caps and inductors of different values in my previous config. I will try to implement the configs that you have provided and hope I will get some results.
I really appreciate the help you have provided so far, many thanks.
The post#12 depicts the circuit in real time but if you are able to get a vague idea, here is the image:
I used multiple arduinos to remove grounding problems (as previously described in older posts). I have not worked on hardware until then because I thought maybe getting some results from the simulation would prove helpful but I am having second thoughts about that now.
and this is the output from the circuit:
When given time and tightening the loose wires, the output looks like this:
The output's "supposed" negative pulses tends to increase in amplitude up to the positive pulses (i.e, the whole output looks like
transitions only.
Unfortunately, I did not print that image from the oscillo.
