gate level simulation,system validation
giri_lp
Member level 3
Can anyone brief me about gate level simulation and system validation concepts?
Thanks in advance
Gate level simulation: check the function on netlist with timing information.
System validatin: Maybe the post silicon test. check the function on real chip.
Hi can any one brief me more about this system validation....
Thanks in advance
Hi ,
People use validation & verification to ensure correctness of the SOC .
Both will ensure SOC will function according to Specification .
One in RTL and other in post silicon ...
Gate Level simualtion is to check dynamic behaviour of the ckt as STA check static timing only . Apart from this all assumption STA ( like multy cycle paths,false paths and other clk exceptions ) are verified in GLS .
Thank & Regards
yln
SYSTEM VALIDATION: It is validating the functional correctness of the WHOLE system by integrating All the BLOCKs in the system.
How Gate lavel simulation gives voilations, is it on path based or only on gate level
Gate Level Simulations gives violations on any signals which are affected due to synthesis. For example, due to some delays statemachines in RTL may go into X state. From such signals identified from Gatelevel netlist, we need to identify, whether it is due to synthesis constraints or due to bugs in RTL design.
Regards,
ramana
