Gas soldering iron for smd components
Adraen
Newbie level 5
Hello,
Sorry if it has been asked before or if my post is in the wrong section, I tried to search for the right section before.
I am looking to replace my soldering irons (I've got two but they are quite bad) mainly for SMD soldering (48 pins tqfp) and seen some gas soldering irons that look quite good hoever I have never soldered with such irons and would like to as if some people did and what was their impressions.
The one i am currently looking at is the dremel versatip as it's quite cheap (£30) and with dremel product i can assure a certain quality.
So, is gas soldering iron any good ? can it be used for smd ?
Thanks.
Regards
Simon.
KJ6EAD
Advanced Member level 3
Earth
It would not be a good choice since the tip selection doesn't include any that are specific to SMD (needle, bent conical, knife, single bevel) and temperature control is practically nonexistent.
I have a gas iron but only use it for field work where I can't easily get power for my other irons.
