GAO HOS220C Handheld Digital Oscilloscope
Supported by stable testing equipments, which are convenient and easy to read during the complicated on-site system, is a visible necessity for all engineers. GAO HOS220C Handheld Digital Oscilloscope is designed to match this kind of needs. This handheld oscilloscope has a sampling rate at 100 MSa/s in dual Channel and 20 MHz bandwidth combining all functions of a digital multimeter (DMM). By using GAO HOS220C Handheld Digital Oscilloscope, you will be confident in solving all troubles more efficiently during on-site occasion.
We have different models to meet your requirement. Please read our GAO Handheld Digital Oscilloscope Product Comparison or Contact Us for more information.
Complete Solution
GAO HOS220C Handheld Digital Oscilloscope can be used as a DMM as well while it is a professional oscilloscope. With this handheld oscilloscope, you are able to measure and inspect wave simultaneously; you will get the stable waves for all kinds of signal automatically by touch in one moment. All test and measure requests can be matched in a second by GAO HOS220C Handheld Digital Oscilloscope
Color Screen
Color LCD panel with the resolution of 320*240, which make the wave easy to be read.Wherever and whenever, you will view the best display for all info by this LCD panel.
Long Endurance and Great Convenience
Total weight of 645g makes carrying more convenient. The protective case for the unit is insulated and is in special designed, this feature guarantees the endurance and credible operation under industrial environment.
Multi-language Display
International language display. Just select any language suitable for you, easy to operate.
Operating Time Up to 6 Hours
Rechargeable li-ion batteries make jobs easy. The max 6 hours operating time helps you to handle the tough working conditions.
Flexible Control Software
One USB based communication software comes with the product, compatible with Win98/Windows2000/WindowsXP and Windows2003.
GAO HOS220C Handheld Digital Oscilloscope Specification
Bandwidth 20 MHz
Real-time sampling rate 100 MSa/s
Rising time 5.83ns
Channels Dual
Independently floating and isolated inputs Yes (for multimeter and between oscilloscope and multimeter)
Time base range 5ns-5s/div
Vertical sensitivity 5mV-5V/div
Trigger modes Edge (Normal, Single shot, Auto), Video
Scope measurements 2 Cursors+5 Automatic
Record length 6K points per channel
Memory for screen and set up 4 Screens;4 set up
True RMS multimeter Volts, Amps, Ohms, Capacitance, Diode,Continuity
Voltage Range 400mV;4V;40V;400V
Accuracy VDC±(1%+1); VAC± (1%+3)
Current DCA:40mA,400 mA
±1.5%±1)
20A
±3%±3)
ACA: 40mA
±1.5%±3)
400 mA
±2%±1)
20A: (±5%±3)
Resistance 400Ω:±(1%+3); 4K,40K,400K,4M:±(1%+1); 40M:±(1.5%+3)
Capacitance 51.2nF-100uF:±(3%+3)
PC interface RS232 cable and USB cable
Power supply 6 hrs Li-ion rechargeable battery
Screen size 3.8 inch color LCD
LCD Resolution 320X240
Product size 180mmX113mmX40mm
Weight 690g
Toronto,Canada-Gao Tek Inc.
GAO Tek Inc., a member of GAO Group, is a leading provider of embedded development tools, telecommunication testers, electronic measurement instruments, video surveillance, alarm and other electronic products that serve the needs of electronic professionals internationally. For further information, please visit
https://www.GAOTek.com.
