gain and phase cross over frequency
shopi Ram
Junior Member level 3
chennai
hai
For a system "with feedback" I have both gain and phase crossover frequency.
My question for this given system to be stable which one ( gain cross over frquency or phase cross over frequency) should be greater?
Also Pls explain me why that should be greater?
Thanks
Shobi
Hi Shobi,
you didn`t mention but I assume you speak about the loop gain response (that means: open loop!), right?
In this case, the gain cross-over frequency (loop gain 0 dB) should be lesss than the phase cross-over frequency (-180 deg or -360 deg, respectively).
In this case, the gain will be below unity (0 dB) when the phase reaches the critical limit and the closed-loop circuit will be stable.
