speedEC
Full Member level 6
Hi all,
I am using PIC18F452 to communicate with Hyperterminal thro' PC serial port. Everything works fine. But, I have to touch the (any) wire on the circuit board to work properly. I guess I left some pin on floating. I can't able to identify the pin. The same problem occurred in PIC16F877A. But I found the pin that I left (LVP) and Disable that pin. After that the entire things worked fine. On PIC18F452 same problem but I can't able to find out the floating pin. Is there any other problem? I have attached the fuse settings that I have set. Please go thro' that and pl provide help.
Thanks in advance.
Thanks in advance.
