functional and formal verification
santumevce1412
Junior Member level 2
functional vs. formal verification
what is the difference between functional and formal verifcation? What r the tools that support these verifications?
Hi
Here i am uploading the verilog pdf...
functional verification vs formal verification
Functional verification means check correspondence of your RTL desciption to your specification. Usually it done by Modelsim, NC-Sim and similar tools.
Formal verification. It is comparing of RTL description (referrence design) with different implementation- after synthesis, scan-chain insertion and so on. Tools Formality, Conformal and others.
Rgds
+functional verification is +rtl +vs. formal
functional verification means verifying whether the chdl functionality is correct or not
but formal verification means by using some assertions u can verify without test bench
go for modelsim
Functional Verification is checking your DUT's behaviour on different inputs combinations...
Formal Verification is checking different possible States covered by you DUT...
functional verification formal
the difference is the approach of the verification itself
in formal verification for instance, you can use mathematical proof to make sure your design is going to function okay...it can be by: theorem proofing, model checking, equivalence checking...and other different methods....
tools: conformal, formality, etc
functional verification is the big umbrella...it's when you verify that your design works fine compared to its specs....formal verification comes under it...along with dynamic verification (simulation)...emulation...linting for HDL...and other ways..
tools: modelsim, ncverilog, etc
formal verification
Functional verification is usually exhaustive, checking all boundary conditions to get a golden RTL, it is prior to synthesis. It is generally done using a tool that does timing verification such as NCSIM/SimVision and ModelSim.
Formal verifcation tools compare RTL golden netlist with mapped/gate level/synthesized netlist using formal techniques and algorithms such as bounded model checking, SMV, CTL, or temporal methods by representing the circuit as canonical binary decision diagrams, Kripke structures or even perhaps Petri nets. Bottomline is to determine whether two circuit structures are mathematically equal i.e. they would produce same boolean outputs. This is a rather quick way of verification as opposed to functional.
formal and functional verification
In EDA industry a subset of formal verification known as logic equivalence check is used mostly for digital designs although formal techniques are being applied to analog designs and mixed signal circuits as well but BDDs and Kirpke graphs are treated as discrete automata having finite states and transitions/paths.
Examples of tools are:
Quartz Formal (Magma)
0-In (Mentor Graphics)
Formal Pro (Mentor Graphics)
Conformal LEC (Cadence)
SLEC (Claypto)
Design Verifyer (Chrysalis/Avant!)
Solidify (Averant)
Formality (Synopsys)
Keep in mind some of these tools are for logic and others are for property checking.
