Function for scaning the 4*4 keypad
mf1364
Full Member level 3
Hi every body
I want a Function for scanning the 4*4 key pad , i am using MicroC compiler . I know that there is function in microC library
but , I want to write my own please help me
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
#include <18F452.h>
#fuses EC_IO,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use delay(clock=4000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
//Keypad connection:
#define row0 PIN_B4
#define row1 PIN_B5
#define row2 PIN_B6
#define row3 PIN_B7
#define col0 PIN_B0
#define col1 PIN_B1
#define col2 PIN_B2
#define col3 PIN_B3
// Keypad layout:
char const KEYS[4][4] =
{{'1','2','3','A'},
 {'4','5','6','B'},
 {'7','8','9','C'},
 {'*','0','#','D'}};
#define KBD_DEBOUNCE_FACTOR 33 // Set this number to apx n/333 where
// n is the number of times you expect
// to call kbd_getc each second
void kbd_init()
//set_tris_b(0xF0);
//output_b(0xF0);
port_b_pullups(true);
short int ALL_ROWS (void)
if(input (row0) & input (row1) & input (row2) & input (row3))
   return (0);
else
   return (1);
char kbd_getc()
static byte kbd_call_count;
static short int kbd_down;
static char last_key;
static byte col;
byte kchar;
byte row;
kchar='\0';
if(++kbd_call_count>KBD_DEBOUNCE_FACTOR)
   switch (col)
      case 0:
        output_low(col0);
        output_high(col1);
        output_high(col2);
        output_high(col3);
        break;
      case 1:
        output_high(col0);
        output_low(col1);
        output_high(col2);
        output_high(col3);
        break;
      case 2:
        output_high(col0);
        output_high(col1);
        output_low(col2);
        output_high(col3);
        break;
      case 3:
        output_high(col0);
        output_high(col1);
        output_high(col2);
        output_low(col3);
        break;
   if(kbd_down)
      if(!ALL_ROWS())
         kbd_down=false;
         kchar=last_key;
         last_key='\0';
   else
      if(ALL_ROWS())
         if(!input (row0))
            row=0;
         else if(!input (row1))
            row=1;
         else if(!input (row2))
            row=2;
         else if(!input (row3))
            row=3;
         last_key =KEYS[row][col];
         kbd_down = true;
      else
         ++col;
         if(col==4)
            col=0;
   kbd_call_count=0;
return(kchar);
void main()
char k;
kbd_init();
printf("\r\Starting ...");
while(TRUE)
   k=kbd_getc();
   if(k!=0)
      if(k=='*')
         printf("%c", '*');
      else
         printf("%c", k);
Reactions: mf1364
    mf1364
Thank you very much Mr ckshivaram , but I am so amateur in c language so can you explain line by line and can you change this code for microC compiler because I am using the Micro C compiler, and I want to show output on a character Lcd so i dont need RS232 protocol by the way so thanks for your reply
