nxhnam
Newbie level 3
- Joined
- Aug 20, 2013
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 29
Sorry for my bad English.
I'm making a full bridge circuit with ir2110 . i use 4 isolated power 5v , 12v(1), 12v(2), 12v(3). The reason is I use power supply for Vb and Vs pin instead of bootstrap .
When I test my circuit in PCB , i provide all 5v and 12V power to driver IC , and there is no problem, but when I continue connect 24V (i do not put the load ) , the right driver is hot , and it died lowside (pin 1 2 3 ), the highside mosfet in right zone is hot but it is not die. The right fuse is break. Then , I put driver one by one (I do not put 2 driver in PCB together) and provide all 12V 5 V 24V , there is no problem .In all case , I dont put HIN , LIN signal to driver .
I hope some help from you
This is my schematic .
Thank you.
Thank you.
