cupoftea
Do you agree that a 4kW Full Bridge LLC converter, with vout = +/-180Vdc and Vin = 390Vdc (PFC output) cannot be done with any offtheshelf gapped ferrite core sizes? (That is, cores that can be bought ready_gapped)
AYK, the biggest gapped ferrite core available offtheshelf is the ETD59 which is offtheshelf gapped to 2mm (AL = 311). However, if that is used as resonant inductor or magnetising inductor of such an LLC, then its core losses will be too high (approx. 10W).
Would you agree with this? Or can you design one which doesn’t suffer such high core losses when only offtheshelf gapped cores are used.
The attached shows the design document for such an LLC. Done at 70kHz….the core losses come out at 10W for the resonant inductor, and 10W for the magnetising inductor, which in both cases uses the ETD59 TDK core with N87 , ready gapped with 2mm gap. These core losses are too much, would you agree?
