hi,
this question arises for half bridge IC PWM pulses.
For Hard switching Full bridge converter, is this type of Time shifted PWM pulses is enough to generate the controlled output voltage?
(or)
Full complementary pulses is required to generate for Half bridge driver IC?
(like, in leading leg, exact complementary pulses is required for top and bottom switches is required? )
Assume i applying 20% duty cycle, (using Full complementary PWM pulses) at S1(top switch 20%) and S2 (bottom switch 80%) will this type of pulses will generate regulated output voltage?
